Online Now [370]:
Visitors: 370
Today: 113906
Total: 155716751
Forums › The Car › 206 Problems › blown a fuse ?
blown a fuse ?
Go to page Previous  1, 2
PostPosted: Wed Mar 02, 2011 12:15 pm Up
Take it forgranted then that you checked all the fuses with you noticing fuse 5 was broke?
If the fuse it fine and the main beam is working, you've either damaged the bulb holder/connector or there's a break in the wiring from the short circuit
davieboy76
PostPosted: Wed Mar 02, 2011 12:21 pm Up
Yeah I checked all the fuses under the bonnet and they were all fine .. The plastic connector that the bulb connects into is damaged it's melted . It was like that when I bought the car and the light was working .. But the plastic holder itself has kinda fell to bits but surely if you plug the spade connectors to the bulb it would still work ?
black 206 hdi s with gti wheels and spolier ...my other cars an evo Wink
Stormcooper
PostPosted: Thu Mar 17, 2011 10:44 am Up
I have the same problem, did you manage to fix yours?
206 GTI
DeadEyePaul
PostPosted: Wed Mar 23, 2011 1:23 pm Up
i found fuse 11 (10 amp) was blown in the fuse box in next to the car battery. i was shouting at my morrettes wondering why the high beam wasnt working on my drivers side. "I kept saying to myself it cant be a fuse, why would they fuse 1 bulb" Laughing
Guess what it was a fuse... Wink
just pull all fuses out one by one and check them. MAKE SURE YOUR CAR'S batttery is disconnected safely
Page 2 of 2
