Latest: Andyblue64
Overall: 17123
Online Now [127]:
Visitors: 126
Today: 8694
Total: 98012747
Forums › The Car › 206 Talk › Where to buy 206 engine mounts
adam_16v
PostPosted: Thu Mar 03, 2011 4:03 pm Up
There doesn't seem to be that much choice out there when it comes to uprated engine mounts and suspension bushes for the 206.
Looking for standard ones, where is the best place to find them? Its for a 2.0 hdi. Just looking for rough prices at the moment.
I know the bottom engine mount is a whole piece, but can you get just the rubber bush part?
a
PostPosted: Thu Mar 03, 2011 4:06 pm Up
dealer.....
if you are looking for uprate bush then peugeotsport...
adam_16v
PostPosted: Thu Mar 03, 2011 4:17 pm Up
Are peugeot as extortionate as renault when it comes to parts?
a
PostPosted: Thu Mar 03, 2011 4:36 pm Up
Peugeot dealer is fine. Don't think I'd like uprated mounts on a diesel!
Vibra Technics make uprated bits for the 206.
