Latest: flipflap
Overall: 17140
Online Now [90]:
Visitors: 89
Today: 40699
Total: 113745532
Forums › The Car › 206 Problems › Warning flashed up and beeped at me
borinous
PostPosted: Fri Mar 04, 2011 5:12 am Up
Last night driving home when i braked for roundabouts i got a warning light flash at me and a beeping like the sound when fuel is low.
Fuel level is fine.
I havent looked in the owners manual yet but the light that flashed was on the right hand side under the one which shows when you have dipped main beam on.
Any ideas??
Hi
PostPosted: Fri Mar 04, 2011 5:17 am Up
Could be low brake fluid (caused by worn brakes usually)
PostPosted: Fri Mar 04, 2011 5:21 am Up
Fuel level is fine.
Any ideas??
Go look in your owners manual Wink
borinous
PostPosted: Fri Mar 04, 2011 5:23 am Up
Pads are relatively new 1-2000 miles if that might be fluid i did think that.
I will look in the manual just aint had a chance yet
Cheers
Hi
Golfguy206
PostPosted: Fri Mar 04, 2011 7:18 am Up
not sure but is you car fitted with brake wear sensors??
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
PostPosted: Fri Mar 04, 2011 7:26 am Up
No 206 has brake pad wear sensors Wink
borinous
PostPosted: Fri Mar 04, 2011 8:03 am Up
Think it was the battery light....just went out to try the car again and it would start not even turn over checked the battery connection and the quick release one closest to the front of the car had come off!!! Think ill be changing this to a standard type connector.
Hi
