Latest: heikkisj
Overall: 17126
Online Now [62]:
Visitors: 61
Today: 14909
Total: 100251205
Forums › The Car › 206 Problems › Misfire Evident
Misfire Evident
Go to page Previous  1, 2
mdstone
PostPosted: Fri Mar 04, 2011 8:53 am Up
Actually, both those sensors cost over £13 when you add on the postage, not so much of a £7 bargain but still cheaper than Pug.
It is on Ignitioncarparts for £11 delivered though - getting cheaper by the minute.
Also, any guesses on why this may solve a rough idle?
Just to clarify, this is not the engine temp sensor is it as mine is fine? I'm just hoping that a new air temp sensor will instantly show the outside temp to what it should be.
Peugeot 206 GTi
mdstone
PostPosted: Fri Mar 04, 2011 8:59 am Up
Sorry I found this which kind of answers my question:
A faulty air temperature sensor that is reading colder than normal will typically cause a rich fuel condition. This wastes fuel and also increases emissions.
A faulty air temperature sensor that is reading warmer than normal will typically cause in a lean fuel condition. This increases the risk of detonation and lean misfire (which hurts fuel economy and increases emissions).
Peugeot 206 GTi
leigh_boy
PostPosted: Fri Mar 04, 2011 12:31 pm Up
i have simialr problem hopefully to be fixed in next few days but min is lumpy when i hold it at revs fine if i pul througth the revs
dianostics said
rpm sensor
knock sensor
and injector 3
i got a knock sensor and some injectors, still got the problem
i also changed temp sensor and crank sensor pugeot think rpm is releated to cam shaft sensor so lets see what happens.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Page 2 of 2
