Latest: ArtistKS
Overall: 17145
Online Now [121]:
Visitors: 121
Today: 2791
Total: 115903051
Forums › The Car › 206 Problems › Boot door rattle
Boot door rattle
clarky78
PostPosted: Fri Mar 04, 2011 8:02 pm Up
There is an annoying rattle coming from my boot door. But no sure what it is. How does the plastic trim come off? I assume it's from the lock or something, but it sounds like somthing is rattling around inside loose. It's been getting worse recently so something must have come undone. Anybody had the same thing?
Black 206 GTI 180
MutilateTheDead
PostPosted: Fri Mar 04, 2011 8:23 pm Up
If you mean the plastic trim inside the boot then you just pull it off (it has ckips on it) Smile
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
PostPosted: Fri Mar 04, 2011 8:45 pm Up
What He Said
Thats what id check out first
mattievrs
PostPosted: Sat Mar 05, 2011 4:30 am Up
If not then untighten the bolts on the boot lock and move the unit in a couple of mm then tighten to stop the boot rattling.
NO LONGER ACTIVE ON THE FORUM
MrrNoName
PostPosted: Sat Mar 05, 2011 4:32 am Up
if its the boot latch you can tighten it, if that wont work you can wrap insulation tape around the bar it locks onto to make it tighter, bit of a bodge job but it does work lol
LilLew
PostPosted: Sat Mar 05, 2011 5:04 am Up
I agree with this i have just done it worked lovely
2003 Pug 206 2.0 GTI 180
