Posted: Sat Mar 05, 2011 6:09 am |
how do you separate the lower half of the bumper thats attached to the front wing do you just pull it down hard??..there is a square bolt but the nut and bolt is turning & i cant get access to hold it..
Posted: Sat Mar 05, 2011 6:14 am |
you'll need to take arch liner that connects to bottom of bumper off. And you can get access this way to hold it square bolt. It can be done by another route but could end up making more damage.
Posted: Sat Mar 05, 2011 6:18 am |
have fun mate they are the most annoying bolts ever designed and put on a car as they always spin
i had this problem with mine when i was replacing my wing, took me a good 30 mins to get a way to get it off
Posted: Sat Mar 05, 2011 6:21 am |
archliner is off but the bolt is just spinning, i just cant hold the square bolt when i turn the nut...
Posted: Sat Mar 05, 2011 6:25 am |
oldbanger2 wrote: |
archliner is off but the bolt is just spinning, i just cant hold the square bolt when i turn the nut... |
yeah thats what i found happened with mine
you will have to employ the help of someone and get a pair of pliers on the edge of the square bolt to try and hold it while someone else undoes the nut from the top
awkward but its the way i managed to do mine
Posted: Sat Mar 05, 2011 6:27 am |
The square bolt head is suppossed to be held by two plastic runners, stupid idea as the plastic just bends! I used two sockets and the bolt snapped in the end, replaced it with a new one and some copper grease in case i ever have to undo it again
Mole grips underneath to clamp it or if it's too tricky try and grip them on top but not too tight as it will ruin the thread Sadly there isn't really another practical way.
