Posted: Sat Mar 05, 2011 9:35 am |
Alright guys, here's one for a 206 boffin...
I was messing around with my interia light today (with the ignition on.....I knoww...) Anyways, as I plugged my LED's back in to the bulb holder, my speakers started to make a high pitched noise. So I turned off the ignition. Turned it back on again and the stereo didn't come on.
Well, after some playing around. I have discovered that the stereo will now only work if the light is set to switch on as the doors open, if the engine is running and some revs are applied (the revs only turn it on. It then stays on unless the interia light is turned on).
Any ideas?
Cheers, Mike.
Posted: Sat Mar 05, 2011 9:37 am |
You have blown the fuse. Quick change and all will be good.
Posted: Sat Mar 05, 2011 9:43 am |
Which fuse? In the box under the steering wheel?
Posted: Sat Mar 05, 2011 10:13 am |
I did the same with mine ages ago, I am 90% sure it was one underneath the steering wheel.
Posted: Sat Mar 05, 2011 10:32 am |
Ah right. Sound. Cheers bud. I'll have a skeet later.
