Forums › The Car › 206 Talk › Gti Throttlebody |
Posted: Sat Mar 05, 2011 10:07 am |
yellow plg on the left hand side any 1 know what it is and what does it do?
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Sat Mar 05, 2011 11:54 am |
any one????
| *DEAD*206 Gti 138
Posted: Sat Mar 05, 2011 12:03 pm |
Is that the heater? I'll dig out a photo.
Yes it's the throttle body heater.
Posted: Sat Mar 05, 2011 12:43 pm |
ah ok thank you, trying to fix the problem with the cars lumpness when you hold it at an rpm and that was loose so thought it might be a problem but probabbly not.
| *DEAD*206 Gti 138
Posted: Sat Mar 05, 2011 1:31 pm |
Try cleaning the map sensor too. Could be the coil pack that's a problem. At a steady rpm the lambda sensor is used so could be that at fault...
