Latest: Andyblue64
Overall: 17123
Online Now [124]:
Visitors: 123
Today: 55316
Total: 98084665
Forums › The Car › 206 Talk › Gti Throttlebody
Gti Throttlebody
leigh_boy
PostPosted: Sat Mar 05, 2011 10:07 am Up
yellow plg on the left hand side any 1 know what it is and what does it do?
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
leigh_boy
PostPosted: Sat Mar 05, 2011 11:54 am Up
any one????
*DEAD*206 Gti 138
PostPosted: Sat Mar 05, 2011 12:03 pm Up
Is that the heater? I'll dig out a photo.
Yes it's the throttle body heater.
leigh_boy
PostPosted: Sat Mar 05, 2011 12:43 pm Up
ah ok thank you, trying to fix the problem with the cars lumpness when you hold it at an rpm and that was loose so thought it might be a problem but probabbly not.
*DEAD*206 Gti 138
PostPosted: Sat Mar 05, 2011 1:31 pm Up
Try cleaning the map sensor too. Could be the coil pack that's a problem. At a steady rpm the lambda sensor is used so could be that at fault...
