Posted: Sun Mar 06, 2011 4:02 am |
| 2002 1.6 5dr Black Edition. | |
Last edited by devildriverxii on Wed Mar 09, 2011 2:17 pm; edited 2 times in total
Posted: Sun Mar 06, 2011 5:50 am |
You need to put a connector on the wires or cut your car wires and wire these in,
As you have frosted lights you can fit male h4 plug to lights and they will plug in to car, I have some if u need any. Or put blade connectors on the wires and push them into the connector.
If u Want to know what wires to connect to what wire I helped somone other day with same thing so have a diagram somewere
Posted: Sun Mar 06, 2011 6:37 am |
Off the top of my head...
Working from left to right
Red = positive on halos [needs connecting to sidlights]
Black = earth
Red = dipped beam
Black = earth
Blue = main beam
They will have H1 bulbs but they aren't any connector atm
Top pin on the H4 connector on your car is for main beam i think, and the one on the bottom that isn't your earth is the dipped beam [might have got them the wrong way around, been a while since i looked]
You'll also need a relay or a stalk to make the dipped beam stay on when the main beam is active. I supply the stalks on a part-ex basis, click my sig for details.
Posted: Sun Mar 06, 2011 10:00 am |
Either way, not an easy install for a novice, I gather.
Also one says h4 and another h1...
Anyone live near Hertfordshire want to do it for reasonable payment =D
Posted: Sun Mar 06, 2011 10:23 am |
I'd do it but it would be a 300 mile round trip so it wouldn't be cheap
They are easy enough to install tho.
Just wire the wires into the correct pin on the car loom side, then if you want the dipped beam to stay on with the main beam you need to fit a relay or changed the stalk [quicker and no extra wiring].
Posted: Sun Mar 06, 2011 10:46 am |
Im awaiting the " How to improve the light output thread " from the op
Posted: Sun Mar 06, 2011 12:01 pm |
My light output with these is fine HIDs do the job.
Lewis
| 206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub | |
Posted: Sun Mar 06, 2011 12:03 pm |
i agree with lee, ive used the "change the stalk option" on both 206's ive had, much easier and faster for me.
... and i know nothing about car wiring iether
Posted: Sun Mar 06, 2011 12:04 pm |
Lewis1304 wrote: |
Roll on 2012
Posted: Sun Mar 06, 2011 4:39 pm |
devildriverxii wrote: |
Anyone live near Hertfordshire want to do it for reasonable payment =D |
about an 1hrs trip according to google maps, but i have no motor atm, feel free to drive up this way if want tho,
have had lots of members come to my house and im not scary (i dont think)
Posted: Mon Mar 07, 2011 10:07 am |
NorthantsBen wrote: |
have had lots of members come to my house and im not scary (i dont think) |
The scary 206 owner lives round the corner
Posted: Mon Mar 07, 2011 1:44 pm |
MrBSI wrote: |
The scary 206 owner lives round the corner |
yer the one with a red 206 with white wheels
Posted: Wed Mar 09, 2011 2:17 pm |
Update.
I fitted the lights today, with a lot of help from Ben, I've just been out to "double check" because it's now dark, and this happend.
Sidelight A stays on with Dipped and Full beams.
Sidelight B Comes on when I put the sidelights on, but then goes off when changed to Dipped or full...which one has a fault, any ideas.
Cheers.
Posted: Wed Mar 09, 2011 2:51 pm |
Strange,
The a one is acting how it should
B is faulty some how, did you cut into the side light cables?
Posted: Wed Mar 09, 2011 3:03 pm |
How have you wired them up?
