Latest: elelectricistadeMateo
Overall: 17127
Online Now [63]:
Visitors: 62
Today: 24066
Total: 100396742
Forums › The Car › 206 Problems › Angel eye problems
Angel eye problems
liambez
PostPosted: Sun Mar 06, 2011 3:20 pm Up
Hi all not sure if iam right to post this here but here goes.
I have just purchased a pug206 as a project to build it back up as its has no MOT or Tax it has rotten sills etc needs a new Rear axle, clutch and loads of other bits here and there. its a x plate and only done 76k. if anyone knows where i can source cheap parts please let me know. Well anyways the problem i have is i got a set of angel eyes and tried to wire them up with out any sort of diagram etc as far as iam aware there h7 connections and pug is h4 so not all plugs fit. The only plug that doesnt fit is the main/full beam wires well i tried guessing where wires went and i guessed right on the drivers side so thought hey will try the passenger side i got it working but thought wiring was incorrect so messed about with it and 2 of the cables touched ( i was stupid and left ignition on while doing this) this has resulted in the passenger light not working altho the halos still do and so does drivers side i have checked the h7 bulbs by eye and they dont seem to have blown.
When its light i will take the lights out and try passenger in drivers etc anyone have any ideas what i may have done before i do this ? thank you for any help. Sad
pug 206 1.4 project car
hatchy1990
PostPosted: Sun Mar 06, 2011 4:21 pm Up
could it not be a fuse that has blown?
liambez
PostPosted: Sun Mar 06, 2011 4:25 pm Up
inside the light unit or in the car ? if in the car wouldnt the Drivers side light not work either ? as drivers side is 100% fine ? if so what number fuse would it be ?
each side has it own fuse iirc
check the fuses under the steering column
hatchy1990
PostPosted: Sun Mar 06, 2011 4:26 pm Up
NorthantsBen wrote:
each side has it own fuse,
What He Said
liambez
PostPosted: Sun Mar 06, 2011 4:36 pm Up
ah will do never new that lol not a french car lover if iam honest but when i got the car for swapping a ps3 i cant really complain lol. any info i should know about these cars other than there french and rear axles are a b***h for breaking.
liambez
PostPosted: Sun Mar 06, 2011 4:54 pm Up
also i forgot to ask on my angels there is 4 lights i know 1 is indicator one is main beam other full beam whats the other ones ? there the highest ones in the light unit as these dont seem to do anything even tho there is a connection to it
PostPosted: Sun Mar 06, 2011 4:57 pm Up
It's Were the side light bulb goes if you want one in Wink
liambez
PostPosted: Sun Mar 06, 2011 5:04 pm Up
rather or aswell as the halos ? also is it illegal 2 put blue ones in ?
As well as the halos.
Yes blue is illegal
PostPosted: Sun Mar 06, 2011 5:05 pm Up
Up to you, I never has side lights fitted, just rings lit up.
And any colour other than white is illegal
liambez
PostPosted: Sun Mar 06, 2011 5:07 pm Up
lol oopsey then ive been driving my astra for the last 3 years with Blue LED's on the inside haha. what fitment will they be ?? same as originals ?
jimjam19927
PostPosted: Sun Mar 06, 2011 7:47 pm Up
Standard 501 sidelight bulb
Member: 685
I Over Use Smilies Razz
liambez
PostPosted: Mon Mar 07, 2011 5:55 pm Up
Standard 501 sidelight bulb[/quote]
thanks thread can now be closed as lights fixed and working.
