Latest: Andyblue64
Overall: 17123
Online Now [340]:
Visitors: 339
Today: 21010
Total: 98292627
Forums › The Car › 206 Talk › look what just arived :)
usher
PostPosted: Tue Mar 08, 2011 8:41 am Up
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
Kersh
PostPosted: Tue Mar 08, 2011 8:44 am Up
jealousss! which ones you go for?
Member number: 36
usher
PostPosted: Tue Mar 08, 2011 8:56 am Up
re profile on both the inlet is the same one pipe sell
would be nice if i had a 180 inlet to go with them but dont have the money or skill to fit it lol
project thread WIP
garage
FAQ
206 gti firedance
MutilateTheDead
PostPosted: Tue Mar 08, 2011 9:52 am Up
How much power gain from these?
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
usher
PostPosted: Tue Mar 08, 2011 10:01 am Up
they say 12 but they say 15 from just the inlet so not sure
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Tue Mar 08, 2011 10:02 am Up
www.pipercams.co.uk/pi...GTI2BP270R
project thread WIP
garage
FAQ
206 gti firedance
drunknmunky
PostPosted: Tue Mar 08, 2011 10:05 am Up
hope you are planning on changing the followers at the same time aswell as the valve springs and retainers?
i want some of these soo bad but the total cost once putting the valve springs and retainers aswell as the followers and everything else is a hell of a lot of money Sad
Kersh
PostPosted: Tue Mar 08, 2011 10:12 am Up
the inlet that you are on about isnt the same, it has a different duration to the reprofiled inlet
Member number: 36
PostPosted: Tue Mar 08, 2011 10:29 am Up
With those cams in the link you shouldnt need to change anything other than the cambelt to fit them. They arent aggressive enough to warrent the change.
PostPosted: Tue Mar 08, 2011 10:30 am Up
damn you piper lol, they didn't give me those decals and lube Sad
kingdom200
PostPosted: Tue Mar 08, 2011 10:32 am Up
get it on the dyno when its done!
PUG1OFF Cat Cams/ ECU project
PostPosted: Tue Mar 08, 2011 10:33 am Up
well, you will have a remap and RR later aren't you? Razz
usher
PostPosted: Tue Mar 08, 2011 10:42 am Up
thats what i was told by piper cheapest option i cant warrent 500 quid on just the cams atm
i can send you the stickers if you want em im not using them
i will be getting a remap in a few month so should have a before and after rr result i also have a std rr print out from when i first got the car so will see how much i have gained overall
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Fri Mar 11, 2011 6:21 am Up
just got it booked in for fitting
cams
belts
water pump
150 quid i been quoted
project thread WIP
garage
FAQ
206 gti firedance
Danw_VVT
PostPosted: Fri Mar 11, 2011 6:27 am Up
thats good shout!
