Latest: flipflap
Overall: 17140
Online Now [244]:
Visitors: 242
Members: 1
Today: 33670
Total: 113780981
Forums › The Car › 206 Problems › How to bleed the GTi coolant system?
PostPosted: Wed Mar 09, 2011 5:30 am Up
I've had a search, but I need more info.
Is this valve here to do with it?
I removed the cap & pushed in the valve stem & it hisses, a lot.
Help please Smile
PostPosted: Wed Mar 09, 2011 5:35 am Up
Is that not the Aircon?
PostPosted: Wed Mar 09, 2011 5:36 am Up
That's what I started to think after a while... Embarassed
PostPosted: Wed Mar 09, 2011 6:18 am Up
Anyone? I need to get this sorted by lunchtime, got it's MOT in a bit.
MrrNoName
PostPosted: Wed Mar 09, 2011 6:27 am Up
gotta feeling you just let all of your aircon gas out lol. (whoopse illegal lol) Laughing
mattievrs
PostPosted: Wed Mar 09, 2011 6:29 am Up
yes that is the aircon!
Best way to bleed the coolant system is to take the cap off the tank then leave the engine ticking over till the coolant in the tank bubbles and the fan kicks in. Then fill it up to the warm mark and do it again.Squeezing the top hose aswell will push the air out.
NO LONGER ACTIVE ON THE FORUM
usher
PostPosted: Wed Mar 09, 2011 7:07 am Up
What He Said
i did this for mine 2yr ago and no problems at all i didnt even start the engine tho Embarassed
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
LilLew
PostPosted: Wed Mar 09, 2011 7:15 am Up
mattievrs is right
Remove your filler cap and top up water start the car leave to tick over for 5mins then top up if needed
Rev the to too 2,000rpm and hold there for 30seconds check water level and repeat until water level does not drop.
2003 Pug 206 2.0 GTI 180
PostPosted: Wed Mar 09, 2011 7:18 am Up
Dime bar.
There is a brass bleed screw in the thermostat housing and one on the heater hose where it goes through the bulkhead.
PostPosted: Wed Mar 09, 2011 7:27 am Up
Edward wrote:
Dime bar.
The one on the hose was fine, where is the thermostat one located?
I think I may actually have a faulty thermostat now as the temp fluctuates randomly, last night I took it for a 30 mile drive, this morning I did 10 on the way to work & it started acting up a bit.
PostPosted: Wed Mar 09, 2011 7:52 am Up
This is the thermostat housing. The copper coloured screw is at the front of it.
PostPosted: Wed Mar 09, 2011 7:54 am Up
Great, thanks!
PostPosted: Mon May 09, 2011 3:31 pm Up
Whereabout in the engine bay is that thermostat located? Laughing
PostPosted: Mon May 09, 2011 11:54 pm Up
Where the top radiator hose goes into the thermostat housing.
PostPosted: Tue May 10, 2011 12:01 am Up
Oh ok just needed a rough idea on how to find it so that should help! Thanks.
