Posted: Wed Mar 09, 2011 8:28 am |
Right ive just been out and bought some proper paint for my car which was made up and i was told it wont need laquer on top as it has a gloss finish anyway so do i need to wet n dry it after its 3rd coat of the paint or not, i want the best finish as possible.
Is it better to wet the sandpaper or have it dry for keying before paint?
Thanks, just confused
Posted: Wed Mar 09, 2011 8:30 am |
Is it for inside or outside the car?
Posted: Wed Mar 09, 2011 8:34 am |
I'd probably lacquer it lightly anyway for abit of protection
Posted: Wed Mar 09, 2011 8:36 am |
Outside and some bits inside, but the guy said thatit wont need any and this is coming from a professional car spraying shop
If it's solid colour or high gloss then only give it a light de nibing after you have finished painting and it's fully dry but you will need a compound like g3 to bring the colour back up. If there is no dirt in the paint when you finished dont bother sanding and buffing it.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Wed Mar 09, 2011 8:39 am |
Surely laqeur gives it it's hard protection coat?
Posted: Wed Mar 09, 2011 8:41 am |
A lot of solid colours aren't lacquered, they just add something to the paint.
Thats why you can get something sprayed in a solid colour in a day
tomd0801754 wrote: |
Surely laqeur gives it it's hard protection coat? |
Agreed. At least tha'ts what I've been told with the vehicle paint I'm using
Posted: Wed Mar 09, 2011 8:42 am |
Yeah i was following same steps aswell but went to the shop and they just said i wouldnt need it?
If it has any nibs Nick do i use the sand paper wet or dry?
Yeah i thought the laquer hardernd the paint and protected it
Posted: Wed Mar 09, 2011 8:43 am |
Lee wrote: |
Thats why you can get something sprayed in a solid colour in a day |
Ahh right, so i dont need to add laquer once sprayeed because it already has some sort of it contained in the paint then
Posted: Wed Mar 09, 2011 8:54 am |
Razpulsedj wrote: |
Don't wet sand paper as it will fall to bits. If you're using "wet or dry" paper, I always use it wet. reduces dust and helps the paper glide over the surface, and helps reduce clogging.
Posted: Wed Mar 09, 2011 8:59 am |
macca1411 wrote: |
Razpulsedj wrote: |
Don't wet sand paper as it will fall to bits. If you're using "wet or dry" paper, I always use it wet. reduces dust and helps the paper glide over the surface, and helps reduce clogging. |
Yeah im using the wet n dry paper so wet that and it will work fine?
Razpulsedj wrote: |
Lee wrote: |
Ahh right, so i dont need to add laquer once sprayeed because it already has some sort of it contained in the paint then |
Not sure if its the same for rattle can. Was my mate who's a sprayer that told me
Posted: Wed Mar 09, 2011 9:02 am |
ill just give it a shot then and see what the results are like, anything has got to be better than my matt black rear lights lol
