Posted: Wed Mar 09, 2011 10:31 am |
I am just dealing with the last of a series of annoying problems. The issue I have is that the sunroof (panoramic) is quite temperamental. It sometimes only goes back a few inches, other times opens fully. It also consistently fails to close all the way. It closes enough to be watertight, but not enough to stop wind noise.
I have resigned myself to removing the headlining next weekend to find out thats going on. Initial thoughts are it is one of three things:
Sunroof motor needs replacing (about £25)
Sunroof cables need replacing (about £35)
Whole sunroof needs replacing (£130)
Any ideas which of those it could be given the symptoms (crosses fingers for motor)
Cheers
-- Phil
| 1999 1.4 LX in Green
2002 1.6 cc in silver | |
Posted: Wed Mar 09, 2011 10:35 am |
my guess would be either of the first two mate. i couldnt see the whole thing needing replacing.
Posted: Wed Mar 09, 2011 10:39 am |
Gonna be lack of use & lack of grease
Posted: Wed Mar 09, 2011 10:57 am |
MrBSI wrote: |
Gonna be lack of use & lack of grease  |
Now that is some good news. Do you reckon the motor will need lubing, or just the runners (hidden question, is there any way I can get out of removing the roof lining?)
Posted: Wed Mar 09, 2011 11:03 am |
Phil_G wrote: |
MrBSI wrote: |
Now that is some good news. Do you reckon the motor will need lubing, or just the runners (hidden question, is there any way I can get out of removing the roof lining?) |
No idea, never done a 206 sunroof
Worked on a 405 electric sunroof, lack of grease / use.
Posted: Wed Mar 09, 2011 3:32 pm |
MrBSI wrote: |
Phil_G wrote: |
MrBSI wrote: |
Worked on a 405 electric sunroof, lack of grease / use. |
Thanks for the advice, looks like I will have to play it by ear.
Cheers
-- Phil
Posted: Mon Jul 11, 2011 10:02 am |
hi i worked on mine i had to rempve the sun visors and lamp an just working in the area of the lamp and the is alan key hole tht i use to move the motor manually after moving it a few times the motor got free and worked great so i made a small hole in the liner under said aln key way so i could close the roof if i got any problems in the future without moving the liner my problem now is the the shuttles that move the roof are broken so i dont have anything holding the roof inplace i want to risk a dismantle\fix so i am looking to see if anyone has a dismantle guide i will keep u posted in the how to guide as to my success .
