Latest: sparrowdclxvi
Overall: 17139
Online Now [562]:
Visitors: 561
Today: 101991
Total: 112913526
Forums › The Car › 206 Problems › engine warning light
Go to page Previous  1, 2
Jubidoo
PostPosted: Thu Mar 10, 2011 9:10 am Up
Message for j4m1e re engine warning light. Not sure if you have solved this, but I recently had similar probably with my 206 and had only had the cat changed some 3 months ago. I took it to kwik fit they put it on diagnostic machine (for no cost) and advised it was coming up as cat problem. So took it back to garage and sure enough the cat was faulty, so they changed it (for no charge as still under warranty) and hey presto light went off. good luck.
My Pegeout 206 is a 2002 plate.
Cheers Jubidoo
Pegeout 206 owner
Jubidoo
PostPosted: Thu Mar 10, 2011 9:14 am Up
Now could anyone help with this problem please. Following my 206 having cat replaced, the rpm display appears to be working backwards!!! I did not notice it at time of picking car up from its little op, but enroute home noticed it, so contacted said garage who advised "oh yes we noticed that and thought it was a bit strange"! Then gave me some reason that "sometimes the needle drops"??? I dont think its illegal to drive with faulty rpm display? And would anyone know how this happened and is it repairable and is it pricey?
Pegeout 206 owner
j4m1e
PostPosted: Thu Mar 10, 2011 11:56 am Up
diagnostic test now complete its either ..... CO2 sensor or the Cat the guy said more likely to be the CO2 sensor as the Cat is pretty protected on the pug's Very Happy
Jamie VW Polo
PostPosted: Thu Mar 10, 2011 11:59 am Up
Whats the code?
j4m1e
PostPosted: Thu Mar 10, 2011 12:20 pm Up
im not sure my mum had to take the car in as i was at work :/ ill see if i can get it and drop it on here tomorrow Smile
Jamie VW Polo
Page 2 of 2
