Latest: kemppu
Overall: 17142
Online Now [55]:
Visitors: 54
Today: 23277
Total: 114062390
Forums › The Car › 206 Problems › cooling/ overheating problem...
robdob
PostPosted: Thu Mar 10, 2011 4:56 pm Up
ive checked tht the fan works, checked all levels of coolant, new temp sensor, thermostat... been told its possible tht could be the fan cut in switch? or maybe the radiator cooling fan relay?? basically, when in traffic etc and the car begins to over heat the fan doesn't cut in... im scared the headgaskets guna warp n cost me more money... help please Sad
PostPosted: Thu Mar 10, 2011 6:17 pm Up
how do you check the fan is working? by turning the A/C on?
starting the car and let it idle for a while until temp reaches 90, fan should kick in, if not, replace the relay
and what do you mean by the car start to overheat? what temp did it reach?
PostPosted: Fri Mar 11, 2011 2:36 am Up
What He Said ,and if the temp is 90 or a bit more,then don't worry,because fan will kick in after 90
robdob
PostPosted: Fri Mar 11, 2011 3:10 am Up
Took the fan out and put power across it... Umm I was stuck in traffic so way way way over what it shudve been so much so tht I had steam coming out the engine bay :(. So u suggest relay for sure??
glenpring
PostPosted: Fri Mar 11, 2011 3:59 am Up
i have this on mine i have had garages look at it and they cant work it out so i think i have put the down to something in the ecu being wrong my car dont have relay and i have changed everything to do with the cooling fan
(fan control, fan, thermostat, even down to changing the loom)
PostPosted: Fri Mar 11, 2011 7:20 am Up
1) turn on the a/c too see if the fan kicks in.
2) turn off a/c and let the car idle until 90 degree to see if the fan kicks in.
if 1=true, 2=false then is relay
if 1=2=false then check the wiring
if 1=2=true then maybe block coolant pipe, water pump or whatso ever
PostPosted: Fri Mar 11, 2011 7:21 am Up
do they have pp2000?
Lewis1304
PostPosted: Fri Mar 11, 2011 7:29 am Up
I have the same problem, I have managed to get hold of 2 new relays, whole new wiring loom for fan and new resistor, £67 from peugeot for lot (friend works there so discount included) Im going to try this too. my A/C doesnt make the fan come on either, however the fan kicks in when it gets to red at full speed.
Lewis
206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub Smile
PostPosted: Fri Mar 11, 2011 7:31 am Up
Lewis
looks like false relay?
since the fan is 2 speed, a/c normal turn on the fan at low speed only.
Lewis1304
PostPosted: Fri Mar 11, 2011 7:32 am Up
What do you mean by false relay dude?
Lewis
PostPosted: Fri Mar 11, 2011 7:36 am Up
i mean fault lol
Lewis1304
PostPosted: Fri Mar 11, 2011 7:39 am Up
hehe Smile well im changing the loom aswell, had a problem where the wire had coroded to green so cut and snip and fitted relay and it worked for a while, I went on a long drive to wales and it stopped working, i have since had digital climate control conversion from manual a/c which looks smart, I just wanna use it to its full potential now!
Lewis
leigh_boy
PostPosted: Fri Mar 11, 2011 7:58 am Up
its the resister in the radiator 100%
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Lewis1304
PostPosted: Fri Mar 11, 2011 8:10 am Up
Well I will change the lot to make sure Smile will the resistor affect the air con too?
Lewis
