Posted: Fri Mar 11, 2011 11:12 am |
Hi Guys (and Girls),
What is the best way to see if I have a Cable System or Hydraulic System for my clutch???
Also the next question that follows on from this is then how do I know which clutch kit will fit my car.. AND if the Kit the only thing I need??
I have a Peugeot 206cc 1.6 s 16v 2003 (03 Reg).
Any help would be Awesome..
Cheers
Kirban
| Peugeot 206 CC - 2003 1.6s 16v - Black with no Mods | |
Posted: Fri Mar 11, 2011 12:28 pm |
When you buy a clutch kit, you use your reg number as reference. That's all they need to know!
Also if you look at the gearbox/clutch housing, if it's wire, you will see where it enters the housing
| No longer a 206 owner
Astra H sxi. 1.7Cdti | |
Posted: Fri Mar 11, 2011 12:36 pm |
apjs87 wrote: |
When you buy a clutch kit, you use your reg number as reference. That's all they need to know! |
I used my Reg on Euro Car Parts and it gave me 4 different clucthes. 2 were cable and 2 hydraulic...
But if your saying there is a way to check by looking at the clutch housing then thats what I'll do. Cheers
Posted: Fri Mar 11, 2011 12:41 pm |
get someone to press the clutch, you will see cable moving pulling an arm on top of box if its cable iirc
Posted: Fri Mar 11, 2011 12:54 pm |
kirban wrote: |
Open the bonnet & have a look
OR
Stick your VIN in to Peugeot Service Box
