Latest: Andyblue64
Overall: 17123
Online Now [31]:
Visitors: 30
Today: 5788
Total: 98009888
Forums › The Car › 206 Problems › Help tightening aux belt...
auto_pug
PostPosted: Fri Mar 11, 2011 1:49 pm Up
Hi all,
I am not longer selling my car as I had a few problems tonight and well it isn't right for selling at the minute.
Basically squeak from the engine bay when the car is idle which from what I have read this tends to be the aux/fan belt and might need tightening but cannot find a guide for this anywhere.
I know what it all looks like etc but I don't know what to do to tighten it and could really do with a diagram or photo to help.
All the forums I find from google bring back the same answers but none of them actually give a guide.
Any help would be great.
James
Peugeot 206 Sport
PostPosted: Fri Mar 11, 2011 1:52 pm Up
iirc self tightens with and auto adjuster, someone will correct me if im wrong im sure.
new belts are not expensive or hard to fit Wink
PostPosted: Fri Mar 11, 2011 2:24 pm Up
you can NOT tighten the belt by yourself,it got a self tensioner that tighten the belt when you start the car,so if your belt is lose,then you need a new tensioner.
Or maybe your belt is worn out,which make it longer with use and the tension it had with time,so a new belt whic is not that expensive,and you car will be back fine.
So I recommend that you change the Belt+tensioner+outside reels which the belt move on them.
Tim
auto_pug
PostPosted: Fri Mar 11, 2011 2:38 pm Up
Hi all,
Thanks for the replies.
How much roughly are those bits likely to cost is it something that could be achieved on the drive way instead of the garage?
Thanks again
James
Peugeot 206 Sport
Ash
PostPosted: Fri Mar 11, 2011 2:40 pm Up
p**s easy to do yourself. £30 on parts ish I think.
PostPosted: Fri Mar 11, 2011 2:43 pm Up
yeah it can be a DIY job,but if you memo. is short,take a pic of the belt going under/above reels and tensioner :D,good luck
auto_pug
PostPosted: Fri Mar 11, 2011 2:48 pm Up
Could anyone point me in the right direction of a link to a guide with possible images?
Again thank you for the help.
James
Peugeot 206 Sport
auto_pug
PostPosted: Fri Mar 11, 2011 3:51 pm Up
I didn't know whether maybe some could scan the couple of pages out of the Haynes manual?
James
Peugeot 206 Sport
