Posted: Fri Mar 11, 2011 2:37 pm |
Right ho peoples, i have two things to ask
1. I have a piper cam sat on my desk, but it has a few deep groves where it sits in the engine circular holders? Not on the lobes
Would this effect it in any way if i put it in?
2. I have H4 morettes and my outer dipped beam is also one of my main beam lenses, (twin filiment) would i need a Hi/Low HID set or would just a low be ok?
Ta muchly
| Team Impossible Possible
Posted: Fri Mar 11, 2011 2:41 pm |
pics may help , i don't know what car you have but if its a twin cam i wouldnt bother just putting one in with out the other as they ware ( spelling ) at the same rate.
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Fri Mar 11, 2011 2:42 pm |
Its an 8 valve
Will do mate
Posted: Fri Mar 11, 2011 3:10 pm |
Posted: Fri Mar 11, 2011 3:12 pm |
That cam is fit for the metal recyling skip.
What happened to the head it came from, bearing's would be well shagged
Posted: Fri Mar 11, 2011 3:16 pm |
Would have thought youd need high/low for your type morettes. (also assuming high beam is needed for MOT and purely for vision it makes sense)
Posted: Fri Mar 11, 2011 3:52 pm |
He run it out of oil
So its knackered? What would it run like with it in?
Posted: Fri Mar 11, 2011 3:57 pm |
Addaz wrote: |
So its knackered? What would it run like with it in? |
Those engine circular holders as you call them are where the camshaft bearings run inside the cylinder head.
It would still run, but not for very long before it shagged the bearings.
Posted: Fri Mar 11, 2011 5:09 pm |
If you can feel the grooves it's past its best. Apart from anything you can see corrosion on it - not good.
Posted: Fri Mar 11, 2011 6:36 pm |
just put the cam on ebay, i am pretty sure someone would buy it lol
Posted: Sat Mar 12, 2011 3:37 am |
A scrap merchant.
Posted: Sun Mar 13, 2011 1:29 pm |
Ahhhh never mind then
Bin bin times
