Posted: Sat Mar 12, 2011 10:57 am |
Right, i bought a window closure unit (thinkin it would be simple) and am very confused.
The unit has wires for positive and negative on the electric windows but on looking at the window switches they have loads of wires. How do i know which are the right ones.
Also does anyone know if i can connect the trigger cable to the deadlocks so the window closure kicks in when i deadlock the car.
Many many thanks for any help!
Posted: Sat Mar 12, 2011 10:59 am |
Give us a clue what window closure unit you have bought
Posted: Sat Mar 12, 2011 11:01 am |
I'll put money on it been the Falcon one.
Get the multimeter out and probe the wires
| Signature removed due to size | |
Posted: Sat Mar 12, 2011 11:03 am |
Flying blind without a wiring diagram.
Posted: Sat Mar 12, 2011 11:05 am |
i got a wiring diagram i will scan it in the morning and post it. Its positive and negative cables to each window but there are lots of wires at the window switch itself.
Posted: Sat Mar 12, 2011 11:07 am |
samreecestrange wrote: |
there are lots of wires at the window switch itself. |
From memory there's only 6 /7 wires for the window switch.
The other plug with all the wires in is for the mirrors
Posted: Sat Mar 12, 2011 11:09 am |
in my eyes thats lots.
Do know what each on is or does.
Posted: Sat Mar 12, 2011 11:10 am |
Cut the UP wire, then you'll have two wires from the module joining that. For the drivers side, you'll need to connect it AFTER the one-touch module if you want to keep your one-touch closure function.
Do know what each on is or does. |
Multimeter and relays = an installers two best friends
Posted: Sat Mar 12, 2011 11:11 am |
Lee wrote: |
For the drivers side, you'll need to connect it AFTER the one-touch module if you want to keep your one-touch closure function. |
Or buy a decent window closure unit & gain a passenger side one touch feature as well
Posted: Sat Mar 12, 2011 11:12 am |
Nope not any more as its been a couple of years since I did mine, multimeter will soon tell you if you probing the correct wire.
how do i know which one is up and which one is down. I dont even understand what a relay does lol
I think im gona stuggle, i gotta fit hids tommorow
Posted: Sat Mar 12, 2011 11:14 am |
See which wire gives +12v when you close the window
I can see a few fuses blown and maybe another BSI
MrBSI wrote: |
Lee wrote: |
Or buy a decent window closure unit & gain a passenger side one touch feature as well |
didnt know you could do that, can u recommend any as that would be much better
