Latest: DanDan17
Overall: 17128
Online Now [205]:
Visitors: 204
Today: 48160
Total: 100648528
Forums › The Car › 206 Talk › 1.4HDI won`t rev past 3,000rpm
gc3746
PostPosted: Sat Mar 12, 2011 11:44 am Up
Hi,
My son has recently bought a 206 HDI 1.4 8v, and the engine seems down on power, it will only rev to 3,200rpm max in neutral with the pedal flat to the floor, definately feels like an electronic limit as the revs just hit a wall and will not increase at all. just before this the engine goes flat.
There are no warning lights showing, I`ve unplugged the MAF sensor and it`s a bit worse. the car has recently had an engine service prior to purchase.
At the moment it`s slower than his 1.9 non turbo Polo he`s replacing.
Any ideas?
Many thanks
gazzer
Antknee
PostPosted: Sat Mar 12, 2011 11:47 am Up
get it code read and see what that throws out, its doing it for some safety reason, whatever it may be
PostPosted: Sat Mar 12, 2011 11:50 am Up
Its in limp mode, normally two or more major sensors are detecting problems or failures. Needs code reading
gc3746
PostPosted: Sun Mar 13, 2011 5:40 am Up
Thanks for your prompt answer, is there anyone in the Cambridgeshire area that can fault code read, as Sheffield is a bit too far.
There is an intermittent beeping sound but no warning lights, I have noticed that there is a screw in sensor at the top of the radiator that appears to be broke but can`t find anyleads that might have plugged into it
gazzer
PostPosted: Sun Mar 13, 2011 5:52 am Up
What year is the 206 in question as from 2004 diesel's had to be EOBD Wink
gc3746
PostPosted: Sun Mar 13, 2011 6:01 am Up
Hi, it`s on a 53 plate but registered 2004, so it would have been registered in jan or feb 2004 so probably a 2003 model.
gazzer
PostPosted: Sun Mar 13, 2011 6:04 am Up
You may get lucky with a cheap EOBD scanner, most mechanics / small garages will have one, you will most likely know someone family / friends who has one.
16 pin diagnostic socket is behind the dash flap to the right of the drivers knee, turn the plastic screw with a coin & then lift / unclip the flap.
gc3746
PostPosted: Sun Mar 13, 2011 6:53 am Up
Ive just tried to start the car and now all I get is a electrical whirring noise from the starter motor, i`ve given it a whack with a hammer to try and free the bendix to no avail any ideas, before I try and remove the most inaccessible starter motor I`ve ever come across.
gazzer
PostPosted: Sun Mar 13, 2011 7:44 am Up
Sounds like starter solinoide to me.
PostPosted: Sun Mar 13, 2011 7:53 am Up
I had to do one Other day on my van that involved removing load of stuff to get to it Laughing
Check the starter earth cables etc
And batt is fully charged.
gc3746
PostPosted: Sun Mar 13, 2011 9:08 am Up
tHE STARTER MOTOR SPINS UP THERE IS NO CLICKING AS THE SOLENOID WOULD HAVE GONE THE STARTER IS ACTUALLY WORKING JUST NOT ENGAGEING IT CAN BE THROWING THE BENDIX OUT TO ENGAGE THE TEETH ON THE FLYWHEEL.
gazzer
PostPosted: Sun Mar 13, 2011 9:39 am Up
Turn your caps lock off Wink
Bendix? ? ?
Starts like the starter is turning but the solenoid isn't firing the pinion gear out to engage with the flywheel ring gear.
gc3746
PostPosted: Sun Mar 13, 2011 2:10 pm Up
Thanks for the help I`ve fitted a new starter £100 and it starts fine now, must of been on it`s way out the last couple of days as it spins up and starts quicker now.
It has the older 16 pin trapiziod shaped plug by the fuse box, same as the one I have for my vw`s,
for the fault codes.
gazzer
PostPosted: Sun Mar 13, 2011 2:22 pm Up
That's the standard socket for all cars these days Wink
gc3746
PostPosted: Sun Mar 13, 2011 2:37 pm Up
Are theses code reader on ebay for around £20 any good, will they wipe any fault codes or just tell me what they are?
gazzer
