Online Now [40]:
Visitors: 39
Today: 35092
Total: 117221656
Forums › The Car › 206 Problems › flowing water sound
flowing water sound
Go to page 1, 2, 3  Next
206qa
PostPosted: Wed Mar 16, 2011 9:55 am Up
Hi,
I'd be grateful if anyone can offer up some advice. I can hear a gushing water sound in my 206 (on the left hand passenger side) when the revs go above 2K, usually in first. This happens when stationary or pulling away (usually on a hill at those revs but can also happen on a flat). Any idea what this noise could be??? It's just your bog standard 2006 verve.
Many thanks Smile
2006 1.4 Verve
3dr hatchback
Quarmbo
PostPosted: Wed Mar 16, 2011 9:57 am Up
Brake servo I think?
Ford SportGay-A
PostPosted: Wed Mar 16, 2011 9:59 am Up
i had that on mine until the heater matrix started leaking.
206qa
PostPosted: Wed Mar 16, 2011 10:06 am Up
So is it a leak somewhere then?
2006 1.4 Verve
3dr hatchback
PostPosted: Wed Mar 16, 2011 10:08 am Up
I got rid of the car before I checked it out. The heater matrix started leaking in the passenger footwell so check to see if its wet there.
PostPosted: Wed Mar 16, 2011 10:11 am Up
First place to look would be your coolant level. MY old Cavalier had this, caused be a leaking gasket.
206qa
PostPosted: Wed Mar 16, 2011 10:12 am Up
Ahh i see. Have quickley popped out and checked it, it's bone dry !
Question
2006 1.4 Verve
3dr hatchback
Abzynthe
PostPosted: Wed Mar 16, 2011 12:28 pm Up
East Area Rep - Abzynthe
DJ, its dried out since the engine change with no signs of leakage, I dont think it was the heater matrix.
206qa
PostPosted: Wed Mar 16, 2011 12:54 pm Up
Read elsewhere it could be an airlock in tge cooling system. Does that sound possible?
2006 1.4 Verve
3dr hatchback
PostPosted: Wed Mar 16, 2011 1:02 pm Up
oh really?! My bad then, i just assumed!
usher
PostPosted: Wed Mar 16, 2011 2:33 pm Up
There is a drain hole in the rear of the sils underneath could be worth a look
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
206qa
PostPosted: Mon Mar 21, 2011 2:33 pm Up
Took it to a garage today, their diagnosis: the head gasket has gone!!! Whether this is the cause of the water sound or the noise is a symptomn they didnt say and as it hasnt been fixed yet i dunno if itll cure it
Thank god warranty is gunna pay for it.
My advice to anyone suffering the same: get it checked!!
2006 1.4 Verve
3dr hatchback
PostPosted: Mon Mar 21, 2011 2:34 pm Up
oh it makes sense now Sad
deanparkr
PostPosted: Mon Mar 21, 2011 6:10 pm Up
Just curious, how is the sound of flowing water relevant to the head gasket?
2002 1.4LX
PostPosted: Tue Mar 22, 2011 5:16 am Up
The water is leaking into the head, causing air in the system, so as it pumps if sounds like a leak. As I first posted.
Page 1 of 3
