Latest: DanDan17
Overall: 17128
Online Now [412]:
Visitors: 411
Today: 40693
Total: 100641069
Forums › The Car › 206 Talk › gearbox oil
gearbox oil
rooney
PostPosted: Wed Mar 16, 2011 2:13 pm Up
weres the bolt on the gti180 gearbox to put oil into it,
i leaked some oil when i was changing the shocks,one of the drive shafts popped out,,
if there's any pic that would be better..
thanks
pug
rooney
PostPosted: Wed Mar 16, 2011 2:16 pm Up
www.206info.co.uk/Foru...=3148.html
lol found it Shocked
pug
MrZiggerz
PostPosted: Wed Mar 16, 2011 2:19 pm Up
MrZiggerz
Good lad Very Happy
rooney
PostPosted: Wed Mar 16, 2011 3:06 pm Up
thanks for the reply
pug
PostPosted: Wed Mar 16, 2011 3:08 pm Up
You dont fill it that way?
Use the reverse sensor hole
PostPosted: Wed Mar 16, 2011 3:10 pm Up
Bodger. Do it properly.
PostPosted: Wed Mar 16, 2011 3:51 pm Up
What He Said
There's a fill / level plug on the end case of the gearbox for a reason.
