Latest: flipflap
Overall: 17140
Online Now [136]:
Visitors: 135
Today: 20402
Total: 113767908
Forums › The Car › 206 Problems › knocking on front driverside
liambez
PostPosted: Wed Mar 16, 2011 5:42 pm Up
hi all i have a project 1.4 16v 3 door thats been stood for the last few years after finaly sorting morealess everything out i decided to take her for a quick test to make sure everything was working and discoverd i have a knocking from the front o/s mostly when turning. it doesnt matter if iam stationary or driving. i thought it may have been the drop link rods so replaced both for new but to no avail. what else could it be ?? any advice is greatly appreciated. thank you in advance
pug 206 1.4 project car
crossie
PostPosted: Wed Mar 16, 2011 5:47 pm Up
Ive got somethink like this so il be watchin this
FOR SALE 206 GTI
PostPosted: Wed Mar 16, 2011 5:49 pm Up
Topmount bearings or / and top mount it self is a posability
liambez
Nice to know am not the only one whos left scratchin there head then. lol
liambez
PostPosted: Wed Mar 16, 2011 6:11 pm Up
where abouts they located Embarassed dont know what am looking for lol
micka
PostPosted: Wed Mar 16, 2011 7:52 pm Up
That's what were are here for, the top mounts are when you open the bonnet there is one either side of the engine bay the top of the suspension unit.
You might want to hold your car wheel on each side and rock it side to side ans top to bottom to see if there is any play in the suspension components.
Above the Redline !!!
liambez
PostPosted: Wed Mar 16, 2011 8:16 pm Up
so basically i gotta have the whole suspension leg off to replace the top mounts ? i do have the spring compressor kit etc so whouldnt be a problem but while doing this is there anything else i should be looking out for or replacing while doing the top mount ?and i presume its the ones under the plastic covers
PostPosted: Thu Mar 17, 2011 3:09 am Up
Yes you do have to take it out to have a look.
Search eBay for 206 top mount there will be some pics of one (I'm on my phone else I would have got some links fir you)
There is a bearing that goes between the rubber topmount and spring seat,
Also check condition on the spring, make sure it is not snapped or not sitting right. And Check for play in the bottom ball joint befor taking it apart that can knock too if worn .
