Latest: TigerHunters
Overall: 17144
Online Now [67]:
Visitors: 66
Today: 3073
Total: 115876552
Forums › The Car › 206 Problems › Throttle Body Problem!
Lewis1304
PostPosted: Fri Mar 18, 2011 1:21 pm Up
Hey Guys,
Had a throttle position problem, so took the throttle body off to give it a clean, wiped all the inside of it out and got all the muck out and then put it back on the car.
Put it back on car, fitted induction etc and then started it up and it revved to 2k straight away and keeps going up and down from 1.5k to 2k revs.
Any ideas what this could be?
Lewis
206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub Smile
fg-mart
PostPosted: Fri Mar 18, 2011 1:30 pm Up
could be your icv mate
martyn
Lewis1304
PostPosted: Fri Mar 18, 2011 1:32 pm Up
Would me of cleaning the throttle body have affected it?
Lewis
PostPosted: Fri Mar 18, 2011 1:35 pm Up
Wouldn't have thought so but you could have tampered with it whilst doing so. Just getting it off, cleaning it and re fitting would be your first step.
Lewis1304
PostPosted: Fri Mar 18, 2011 1:36 pm Up
Harry, I took it off and refitted it. I even put on another throttle body I have in my garage... Still no luck...
Lewis
PostPosted: Fri Mar 18, 2011 1:46 pm Up
You replaced the whole throttle body and the same thing still happened?
PostPosted: Fri Mar 18, 2011 1:49 pm Up
The 16V doesn't have an idle control valve does it?
mattievrs
PostPosted: Fri Mar 18, 2011 1:50 pm Up
Did you put the gasket back on and tighten it up? Sounds like either an air leak or you might need to reset the ecu via unplugging the battery for 30 mins then letting it idle on its own for a couple of minutes.
NO LONGER ACTIVE ON THE FORUM
make sure there in no air leak between the throttle body and intake manifold and gasket is ok.
EDIT: as above me. Laughing
Lewis1304
PostPosted: Fri Mar 18, 2011 1:53 pm Up
there's a tiny little gap between the inlet and throttle body but i thought it was normal... should i tap it on with a hammer so its on mega tight, leave the battery off for 30 mins and reset ecu too?
Lewis
Lewis1304
By the way guys, gasket? there was no gasket....
Lewis1304
PostPosted: Sat Mar 19, 2011 8:12 pm Up
Sorted! just needed error code erasing!
PostPosted: Sat Mar 19, 2011 9:23 pm Up
weird.
Lewis1304
PostPosted: Sun Mar 20, 2011 6:53 am Up
Very! All sorted now! Im not complaining. It is now popping and banging now!
