Latest: DanDan17
Overall: 17128
Online Now [248]:
Visitors: 247
Today: 24962
Total: 100585635
Forums › The Car › 206 Problems › temprature on 2l hdi
goughy
PostPosted: Sat Mar 19, 2011 2:48 pm Up
hi all im new on here so be gental Smile ive noticed the temp gauge only goes 1/4 of the way up the dial, is this normal? thought it should go to 1/2 way when at normal temp, do you think the thermostat will need changing? if so is there a how to, cheers colin
206 2l hdi sport
Antknee
PostPosted: Sat Mar 19, 2011 2:50 pm Up
Not sure about the 2L but tis normal on the 1.4
PostPosted: Sat Mar 19, 2011 2:52 pm Up
which temperature gauge? there is 2, one is coolant one is oil
goughy
PostPosted: Sat Mar 19, 2011 3:43 pm Up
its the 05 so its only got the one Confused !!!!!!!!! i think Question
206 2l hdi sport
perry081064
PostPosted: Sat Mar 19, 2011 3:48 pm Up
mines a 2l hdi diesel 2001 (y plate)
only has coolant temp and this rarely go's above 70 , usually after a good run about 75.
206 2.0 HDI
goughy
PostPosted: Sun Mar 20, 2011 4:05 pm Up
should be ok then it's just when i had my bmw td i was told if the temp didnt reach half way on the gauge within 5 mins of driving the stat was failing and mpg would be pore Confused
206 2l hdi sport
Jay794
PostPosted: Sun Mar 20, 2011 4:32 pm Up
Mine has oil & engine and it's an 02, the oil barely goes above 80 and the engine temp sits around 90
stevedude
PostPosted: Sun Mar 20, 2011 4:38 pm Up
my 03 sits around 75-80
not got oil temp
Happydays
cartoonhead
PostPosted: Sun Mar 20, 2011 5:19 pm Up
mines 01/Y and i have the 2 gauges
waters normaly around 70 and oil is below the 90 mark Smile
panason1c
PostPosted: Mon Mar 21, 2011 2:49 am Up
Generally, normal operating temp should be a minimum of 80 and maximum of 90...........less than 80 means a new thermostat is needed.
My 1.4hdi normally sits at just above 80 and just below 90 if i'm pushing it hard up a hill.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
