Posted: Sun Mar 20, 2011 3:42 pm |
I have a rattle coming from somewhere inside the interior of the car, i've removed the centre console and its not there, how do i
remove the rest of the interior ie near the front window vents, basically how to you remove all of the front interior?
| 206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out! | |
Posted: Sun Mar 20, 2011 3:53 pm |
Check that the frame for the gearknob gaiter is fully pushed down, this caused a rattle for me
Posted: Sun Mar 20, 2011 3:56 pm |
removed
Posted: Sun Mar 20, 2011 3:57 pm |
You don't want to remove the dashboard...
Remove the glovebox, a number of screws & check behind it for any loose trim/wires.
Posted: Sun Mar 20, 2011 4:16 pm |
It sounds like it's right at the front of the car, near the windscreen vents
Posted: Sun Mar 20, 2011 7:33 pm |
Its french, its going to rattle no matter what.....
Posted: Sun Mar 20, 2011 7:39 pm |
Trade Rating: +36
Not that it has anything to do with your problem but I owned a corsa about 8 years ago that used to have a rattle and after months of it getting on my tit's i finally had it looked at and it turned out to sycamore leaf in the heating duct
Posted: Sun Mar 20, 2011 8:04 pm |
Turn the music up.
