Latest: tc.206
Overall: 17147
Online Now [63]:
Visitors: 62
Today: 19164
Total: 116364659
Forums › The Car › 206 Talk › b pillars
b pillars
tiago90
PostPosted: Mon Mar 21, 2011 8:54 am Up
how do i remove them ?
Cant find anywhere an how to do it :s
PostPosted: Mon Mar 21, 2011 8:57 am Up
there's a plastic bit that you pull to adjust the seatbelt height. Pull that off, it may be stiff but will come off.
Think it's a torx 10 or 15 bit you need to undo the lower cap of over where the seatbelt is attached. Undo that which will expose a bolt.
Undo that and the seatbelt will fall out.
Then prise the pillar off at the top and pull off.
Hope that helps
tiago90
PostPosted: Mon Mar 21, 2011 8:58 am Up
cheers will try that.
didnt want to pull it to hard in case i would break it lol
Tom206
PostPosted: Mon Mar 21, 2011 10:05 am Up
on my first 206 it was a pain and left all sticky crap. I proffered it with.
2002 2.0 HDi SP
www.facebook.com/tomwebb01
PostPosted: Mon Mar 21, 2011 10:08 am Up
Make sure you pull the adjuster thingy evenly. Wink I didn't, it snapped in half. Although not an issue, it just looks untidy.
