Latest: Mr-Koekwaus
Overall: 17125
Online Now [280]:
Visitors: 279
Today: 41139
Total: 100123867
Forums › The Car › 206 Problems › ABS kicking in
ABS kicking in
Lecktorious
PostPosted: Mon Mar 21, 2011 2:41 pm Up
Trade Rating: +59
Right there's not a lot of info on the DV6 - would I be right in saying it will use the same driveshafts as the GTi 138? Checked Service Box but it doesn't state the diameter of the ABS ring.
'98 Nile Blue 306 GTi 6
PostPosted: Mon Mar 21, 2011 4:00 pm Up
Could you measure the driveshaft diameter? ? ?
Lecktorious
PostPosted: Mon Mar 21, 2011 4:12 pm Up
Trade Rating: +59
I could aye but it's a bit dark for that now! Laughing whats your thoughts then Lee, I assume you got my PM? Razz
PostPosted: Mon Mar 21, 2011 4:16 pm Up
I did & I reckon its gonna be the same drivetrain with different gear ratios as the GTI apart from the FAPTASTIC peice of French engineering under the bonnet powering it all Wink
Lecktorious
PostPosted: Mon Mar 21, 2011 4:18 pm Up
Trade Rating: +59
Cheers mate! Just wanted to check someone like yourself was thinking along the same lines as I was. Will order up a couple of replacements shortly Smile
PostPosted: Mon Mar 21, 2011 4:21 pm Up
Soon find out Laughing
PostPosted: Mon Mar 21, 2011 4:28 pm Up
Yes it's all the same transmission bits on the smelly diesel...
Lecktorious
PostPosted: Mon Mar 21, 2011 4:29 pm Up
Trade Rating: +59
Cheers Paul Laughing
mdstone
PostPosted: Mon Mar 21, 2011 5:12 pm Up
G. you never said if your ABS fault warning came up on your car? Mine has noe finally gone but comes back every couple of days. I think a new sensor is likely for me.
Peugeot 206 GTi
Lecktorious
PostPosted: Mon Mar 21, 2011 5:15 pm Up
Trade Rating: +59
Aye it flags up, comes om over 80 and stays until you stop and restart the car then it clears.
panason1c
PostPosted: Wed Mar 23, 2011 5:34 am Up
Check to see if one of the tyre pressures is significantly lower than the others which would affect the rolling diameter of the individual wheel and trigger an abs fault, similarly, if one of the tyres is worn more than the others.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Lecktorious
PostPosted: Wed Mar 23, 2011 4:52 pm Up
Trade Rating: +59
Not checked the pressures in a while, will give that a shot and then order up new sensors if no joy.
mdstone
PostPosted: Fri Mar 25, 2011 7:01 am Up
Interesting, my O/S/F is worn more and ABS light comes on now and again. Also the ABS has kicked in when pulling away from low speed. Not often though.
Lecktorious
PostPosted: Sat Mar 26, 2011 5:33 pm Up
Trade Rating: +59
Cracked ABS ring on the passenger driveshaft - replacement for both side on order!
Lecktorious
PostPosted: Sun Mar 27, 2011 3:15 am Up
Trade Rating: +59
Anyone got a 'how-to' on reolacing the ABS rings?
Page 2 of 3
