Latest: sparrowdclxvi
Overall: 17139
Online Now [148]:
Visitors: 147
Today: 16868
Total: 113544496
Forums › The Car › 206 Problems › cant find the knock after lowering
Danpotter
PostPosted: Mon Mar 21, 2011 10:58 am Up
hi all. i just lowered my car and a week later ive got a knock/clonk on the rear. only done about 20 miles. ive checked for play in the back wheels and there's no noises not even from the axel bearing. i put a bar under the wheel and lifted the wheel up and down. i even rocked the car side to side but still no noise. i only get a knock at low speeds round corners. can any help!! am i checking the axel bearing wrong? cheers
Big_Rich180
PostPosted: Mon Mar 21, 2011 11:06 am Up
I think with the axel bearing you just see if there is any play isn't it, could in not be the exhaust knocking or maybe worn bushes on the supporting arms?
Danpotter
PostPosted: Mon Mar 21, 2011 11:25 am Up
the exhaust is fine and the spare wheel is tight.
206 gti
Big_Rich180
PostPosted: Mon Mar 21, 2011 11:27 am Up
Sorry, i assumed it was a 180 for some reason.
Andy180
PostPosted: Mon Mar 21, 2011 1:17 pm Up
checked if this shocks are tightend up properly i had this problem on mine
GTI 180
PostPosted: Mon Mar 21, 2011 1:22 pm Up
You say you have gone 20 miles, has the knock been for all of that time? or has it only started are lets say after 15.
chris_rock206
PostPosted: Mon Mar 21, 2011 1:38 pm Up
could be ure bushes cuz my mate has 306 and he went through everything altho somein tells me it was his sub frame i'll ask him and let you know weather it was bushes or the sub frame knockin but thats just something you could look at like.
Danpotter
PostPosted: Mon Mar 21, 2011 2:50 pm Up
I have done bout 20 mile now since i first heard it. I done bout 10 mile before the noise first happened. Shocks are all tight.
206 gti
Harty
PostPosted: Mon Mar 21, 2011 3:23 pm Up
loose anti roll bar Wink had it on my old gti... exactly the same symptoms
Chris
Harty
meady
PostPosted: Mon Mar 21, 2011 3:38 pm Up
Trade Rating: +45
I think it is the anti roll bar, as i also had this after my gti was lowerd, it started knocking when going over bumps (sounded like i had drove over a loose drain cover) is the anti roll bar inside the rear axle ???
TEAM - I HATE FACEBOOK Smile
Harty
PostPosted: Mon Mar 21, 2011 3:40 pm Up
Yeah i think so, edward has a how to on uprating it on here
Chris
Harty
meady
PostPosted: Mon Mar 21, 2011 3:41 pm Up
Trade Rating: +45
what do you mean uprating it, it just needs tightning up and tht should do the trick Smile
Harty
PostPosted: Mon Mar 21, 2011 3:43 pm Up
Yes but the how to shows you how to access it Wink
Chris
Harty
Danpotter
PostPosted: Wed Mar 23, 2011 3:19 pm Up
thanks for the help. i didnt undo the anti roll bar but could it of come loose on its own?
206 gti
Andy180+
PostPosted: Wed Mar 23, 2011 3:25 pm Up
anti roll bar is inside the axle tube so if you did not disconnect while lowering the axle it would have come off by itself as the arms have been moved, best taking off the two end caps on the arms and having a look . easy enough to do.
