Latest: dreyfalon
Overall: 17121
Online Now [564]:
Visitors: 563
Today: 82211
Total: 97608493
Forums › The Car › 206 Problems › Blower motor problem?
rich1162
PostPosted: Tue Mar 22, 2011 4:07 pm Up
I'm having a few problems which I think are being caused by a dodgy blower motor. I've got climate control fitted and recently fans only seem to have two settings, full blast or none at all.
If i use the +/- button to turn the fan speed to full then it works ok, i can slow it down by 1 or 2 presses but after that it just makes a whislting noise and no air comes out. I think this could be down to a knackered blower motor but I don't want to go changing parts without knowing for sure.
Am I right in thinking it's the blower motor or could it be something else? Is there anything I ca do to test it or is it going to be a case of trial and error?
Thanks,
Rich
Rich :: 2001 1.4 GLX
MrrNoName
PostPosted: Tue Mar 22, 2011 4:19 pm Up
i have the same problem currently with my standard (non climate controlled) blowers,
with my controls its not the blower motor itsself, its the blower motor resister. its essentially 4 coils of wire, each with a different resistance. depending on what setting you have the blowers on, the circuit runs through different coils. when this goes wrong some of the coils go, meaning that some settings have power and some have none.
im not sure if climate control uses a blower motor resister in the same way? might be worth finding out
its cheap to replace but a hassle to get to, thats why i havnt done mine yet!
stevedude
PostPosted: Tue Mar 22, 2011 4:33 pm Up
yeah sounds like the resister to me, i had the same thing on a 306, cheap to do Smile
Happydays
rich1162
PostPosted: Wed Mar 23, 2011 4:20 pm Up
Cheers guys, at least I've got somewhere to start now. I'm going 2 have a go at it this weekend, I'll let u know how it goes...
