Latest: jtq4u
Overall: 17141
Online Now [160]:
Visitors: 159
Today: 59230
Total: 113966124
Forums › The Car › 206 Talk › 1.6l 16v - Anyone got one??
mattievrs
PostPosted: Tue Mar 22, 2011 2:27 pm Up
Lee wrote:
It more than likely won't.
What linkages are you getting? Make sure they are for the MA gearbox, as the majority that are sold are for the BE Wink
To be honest mate I don't know the differance between the gearbox's, I have been recommended these
cgi.ebay.co.uk/ws/eBay..._925wt_905
But if you know any better please share :lol:, I'm hoping by installing these and the quickshift i will at least make the gear change's a bit more pleasant.
I had those and a griffiths quikshift, ended up chewing the diff in the gearbox....on an xsi Confused
NO LONGER ACTIVE ON THE FORUM
-Dave-
PostPosted: Tue Mar 22, 2011 2:32 pm Up
Trade Rating: +36
It was you that I spoke to a while ago about it Laughing , A few people have said though that the griffiths is not that bad on my model 206, But someone did say they are not that good on the GTI or the 180, I may be mistaken but I need to do something because my gearbox is doing my nut in. Only thing about the car I can't stand.
Ex 206 Owner.
XSIcheeseman
PostPosted: Tue Mar 22, 2011 5:37 pm Up
Addaz wrote:
Xsi cylinder head
106 Gti bottom end
C2 Vts inlet manifold
Ported TB
4-1
= WIN
how much you think that might come to?
106 Gti bottom end - would you need the summp and the pistons and stuff?
PostPosted: Tue Mar 22, 2011 5:47 pm Up
XSIcheeseman wrote:
Addaz wrote:
Xsi cylinder head
106 Gti bottom end
Ported TB
4-1
= WIN
you wouldn't be able to just buy the bottom end of the engine.
you will have to buy the whole engine and then remove the cylinder head.
XSIcheeseman
PostPosted: Tue Mar 22, 2011 5:48 pm Up
would you need the pistons and conrods and the big end bearings?
New and Improved!
New Project
www.206info.co.uk/Foru...51199.html
PostPosted: Tue Mar 22, 2011 5:53 pm Up
of course you will need it...
how can you run the engine without them in..? Confused
XSIcheeseman
PostPosted: Tue Mar 22, 2011 5:57 pm Up
i mean the 106 pistons and stuff or can i just use the 206 ones? cause if i can get a crank and sump
New and Improved!
New Project
Golfguy206
PostPosted: Wed Mar 23, 2011 7:11 am Up
What benefit would you get form the C2 VTS manafold??
and what does "ported TB" mean??
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
PostPosted: Wed Mar 23, 2011 7:13 am Up
It's polished & widened slightly.
Addaz sells them Razz
mattievrs
PostPosted: Wed Mar 23, 2011 7:17 am Up
The quikshift on its own made a massive difference, i then cut an inch off the gearstick and it felt really close and postive through the changes. I then added the stainless rods and within 2 weeks the diff was stuffed.They were measured exactly the same as the old rods aswell.Could of been a coincidence but who knows.
Golfguy206
PostPosted: Wed Mar 23, 2011 9:24 am Up
I know what porting & polishing is, just was kinda confused by the "TB" bit.
PostPosted: Wed Mar 23, 2011 10:36 am Up
throttle body
PostPosted: Wed Mar 23, 2011 10:37 am Up
C2 VTS inlet manifold has a much better flow than any inlet manifold on the J4 or JP4 engine
Golfguy206
PostPosted: Thu Mar 24, 2011 2:57 am Up
hmmm. another interesting thought! l
Looks like I could be searching for a C2 VTS manafold then!!
Anyone seen one in a scrap yard???
PostPosted: Thu Mar 24, 2011 8:05 am Up
this is nearly impossible, and you would be struggle to find one on ebay too Laughing
Page 3 of 4
