Online Now [561]:
Visitors: 560
Today: 151405
Total: 156503434
Forums › The Car › 206 Problems › PP-T40 on '02 206XS 1.4i 8V
zoranm1976
PostPosted: Wed Mar 23, 2011 10:18 am Up
I have on my car One line DATE/TIME display with CD info and RDS and I would like to update it with bigger display possibly with trip fuel consumption etc.
So I found PP-T40 on e-bay part number 9650242977 3 bulb type.
1 question which type is this. From picture i see that is bigger screen then mine but you can't newer know because sometimes pictures can be disproportional.
2 question will it fit to my mid 2002 206 XS
Mid 2002 206 1.4i XS LPG converted
PostPosted: Wed Mar 23, 2011 10:26 am Up
You may require a new Com2000 unit or an BSI update.
PostPosted: Wed Mar 23, 2011 10:38 am Up
You will need a new centre console hood (plastic surround) as the clock is smaller.
At least that's the case for non plexed clock - ppt30 I persume it's the same.
zoranm1976
PostPosted: Wed Mar 23, 2011 10:49 am Up
Yeah I thought so but I think that my comm2000 is capable for BSI I don't know maybe I'll take it to the dealership to program it with lexia.
My Comm 2000 has other than normal turn signals, lights, front and rear wipers front and rear fog lights and radio control stalk. but it does not have auto lights and BC button. I found on this forum that it can be done by switching top cap on the wiper stalk.
zoranm1976
PostPosted: Wed Mar 23, 2011 10:55 am Up
It looks the same no the picture but I will check with guy who has GTI with multifunction clock.
skard
PostPosted: Wed Mar 23, 2011 10:58 am Up
the MFD is plug and play (as yours is multiplexed and so is the 3 bulb MFD). you won't have to change to console plastics or anything.
pop the end cap off your wiper stalk and see if there is a button down there for trip function. i took the springy cap from a broken wiper stalk and installed it onto my non-trip comm2000 - as seen on pic below
you may not need a BSI reconfiguration - i didn't - but i guess it depends on your software version.
zoranm1976
PostPosted: Wed Mar 23, 2011 11:04 am Up
Thanks for quick reply. I thought it will be straight forward plug and play installation but i had to check first before buying it on e-bay.
So the part number from first post is correct for MFD like yours?
PostPosted: Wed Mar 23, 2011 11:07 am Up
You might not need a BSI update, it might just need turning on in the BSI. I've done a few of them in the past couple of weeks. A lot them already have the capabilities, it just needs turning on.
skard
PostPosted: Wed Mar 23, 2011 11:09 am Up
yes i had a single line PPT40 initially, and got a multiline one like that - you need a 3 bulb type, a 4 bulb type is for pre-plexed
zoranm1976
PostPosted: Wed Mar 23, 2011 11:14 am Up
Thanks Lee. When i looked no pictures skard posted i see that MFD is in miles and my car is form Germany so it will need some reconfiguration possibly because PP-T40 from e-bay is also form UK
skard
PostPosted: Wed Mar 23, 2011 11:16 am Up
i think you can alter the units of measurement with the MFD buttons
PostPosted: Wed Mar 23, 2011 12:02 pm Up
Yeah you can change it with the buttons [tells you how in the owners handbook], or when you get it activated in the BSI just tell them to do it.
You just go into the Mutlifunction Display ECU and change the settings
PostPosted: Wed Mar 23, 2011 2:15 pm Up
Depends on if you have a factory fit cd changer Wink
zoranm1976
PostPosted: Wed Mar 23, 2011 4:01 pm Up
Thanks all for prompt answers.
MrBSI i don't have factory fit CD changer.
zoranm1976
PostPosted: Sat Apr 02, 2011 12:51 pm Up
Guys thanks a lot.
Everything is working like charm. I bought ppt 40 multiline display from ebay for 28£ plus 10£ shipping to my country. I disconnected battery following the 3 minute rule. Then I connected new MFD, connected battery again, turned on sidelights and after that ignition. I got date and time on the MFD and after turning radio on other info from radio in new format.
But I don't have temperature because sensor is not in the mirror.
I tried to swap wiper stalk top part from friend but we broke the stalk due difference in design of his.
Next thing I did is put little straw from wd 40 in little nipple inside the cap from my stalk and returned on stalk and voila button is working. Ofcourse I had to cut the straw to fit inside. But it is working and without spring inside.
Now i have to find temp sensor to finish the work.
