Latest: Andyblue64
Overall: 17123
Online Now [340]:
Visitors: 339
Today: 22154
Total: 98293771
Forums › The Car › 206 Problems › Stiff Clutch HELP!
Stiff Clutch HELP!
dainbramaged01
PostPosted: Wed Mar 23, 2011 2:27 pm Up
I was hop[ing one of the mechanical geniuses on here might help me out my car is a 2.0 HDI Turbo 2002 Model.
The problem is i got in my car after leaving it in gear on a hill and driving home the clutch pedel had become stiffer when depressing the pedal?
My first thoughts where cable needs lubrication (not even knowing if its cable or hydraulic) but no i think maybe the thrust bearing is going??
Has anyone got any advice?
Andy180+
PostPosted: Wed Mar 23, 2011 3:07 pm Up
sounds like bearing seizing up on the input shaft sleeve tbh. new clutch and clean up sleeve and lube should do the trick
scottsgti
PostPosted: Wed Mar 23, 2011 4:54 pm Up
if you're thrust bearing is going u will know about it. my old polo 6n had the thrust bearing go. and oh my god did it make some cringe worthy noises.
but if it does turn out to be the bearing, and it is anything like my old one, it will deteriorate very quickly, so within a matter of weeks you'll know if it is infact the bearing.
moonstone blue 206 gti 138, sp kit. completely standard
