Online Now [508]:
Visitors: 507
Today: 184011
Total: 154563121
Forums › The Car › 206 Problems › GTi 180 - Steering Problem
cr21
PostPosted: Thu Mar 24, 2011 8:25 am Up
Hey guys
Been having this problem for a few months now. When parking i hear a sort of clunking sound when turnin the steering wheel towards full lock, which happens in both directions. This happens when both the car is stationary or moving.
Then when im driving in a straight line, the car pulls to one side. But it doesn't always pull to the same side which im guessing has something to do with which way i turned full lock to last. Im guessing it has something to do with the steering and / or driveshafts but really am unsure.
Any help would be much appreciated.
GTi 180
PostPosted: Thu Mar 24, 2011 8:32 am Up
top mount bearing
eddrj
PostPosted: Thu Mar 24, 2011 8:33 am Up
yeah like above the top mount i had that few months back.
Old car 2000/ 206 2.0 hdi.
BobbyD
PostPosted: Thu Mar 24, 2011 11:07 am Up
my 180 seems to pull side to side when driving about 60 or 70 mph and my top mounts are brand new. Just dont seem to stable somehow.
*BobbyD* -- Current Car: GTI 180
cr21
PostPosted: Thu Mar 24, 2011 5:15 pm Up
Ok thanks for the replies guys! So will this be expensive to repair and also is it an easy enough task to carry out? Cause id like to avoid taking it to a garage if i can but the fact im not even sure what the top mount bearings are, probably means i wouldnt be able to do this!!!
GTi 180
PostPosted: Thu Mar 24, 2011 5:19 pm Up
tracking done? tyre pressure? tyre correctly mounted?
any play in the suspension component?
wheel bearing? or even rear axle?
PostPosted: Thu Mar 24, 2011 5:20 pm Up
the bearing itself is cheap, probably around 10 quid each.
but you will have to take off the front suspension in order to fit it.
cr21
PostPosted: Thu Mar 24, 2011 5:35 pm Up
Ok cheers. Taking the front suspension off sounds like quite a big job so a garage job it looks like. Hopefully wont be too expensive tho since the actual part is self is pretty cheap!
GTi 180
