Latest: dreyfalon
Overall: 17121
Online Now [554]:
Visitors: 553
Today: 57764
Total: 97584068
Forums › The Car › 206 Problems › anoying ticking noise
minimuff
PostPosted: Thu Mar 24, 2011 2:44 pm Up
ok i have the 05 plate 206 1.6 16v tu5jp4 engine in my 206 and there is this annoying ticking noise at idle but the minute i put a bit of throttle on it goes away. it seems more like a bottom end noise rather that valve train noise. i have checked oil pump and chain and they are fine. another annoying thing after letting it run for a bit it goes away. and when starting the car it deosnt make the noise straight away , it kinda come in slowley getting louder . iv ran the car for about 6000 miles with this and its not had any issues but i need to get rid of the noise before i sell it.
i had a thought about mabay timing belt and tensioners ?
any help or ideas are much appreciated or if anyone has had the same problem .
thanx martin
frenchi
panason1c
PostPosted: Thu Mar 24, 2011 4:41 pm Up
Possibly a hydraulic tappet causing the noise, nothing to worry about if left, sometimes an oil change will help to quieten it.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
minimuff
PostPosted: Thu Mar 24, 2011 5:14 pm Up
thanx for the reply
iv done 2 oil changes and its not helped. i though hydraulic tappet at first but i thought that it would still make the noise when reved but when throttle is pressed it goes away.
i dont want to take it to peugeot incase they just rob me Lol.
frenchi
panason1c
PostPosted: Fri Mar 25, 2011 2:26 am Up
Revving the engine will increase the oil pressure in the tappet which makes the noise go away.
BMW K1200RS
ryanbfox
PostPosted: Sun Jul 31, 2011 5:00 pm Up
i get the opposite lol, i got a problem with my car, it sounds like a hollow ticking noise from the engine bay, the funny thing is it only happens when i accelerate, in idle its quiet and when i de-accelerate you can here it??? can anyone help?
Ryan
ryanbfox
PostPosted: Sun Jul 31, 2011 5:01 pm Up
sorry when i de-accelerate you CANT here it
Ryan
southwestchap
PostPosted: Mon Aug 01, 2011 4:30 am Up
crankshaft pulley rubber worn?
ryanbfox
PostPosted: Mon Aug 01, 2011 2:08 pm Up
apparently it might be the exhaust manifold
Ryan
