Latest: kemppu
Overall: 17142
Online Now [114]:
Visitors: 113
Today: 27233
Total: 114033013
Forums › The Car › 206 Problems › Pink fluid dropping underneath the stereo, SCARED, help me
montysingh
PostPosted: Fri Mar 25, 2011 5:02 am Up
Hi All
I got this weird issue as my car is leaking some sort of oil underneath on the floor at the front of the car, its right underneath were the engine is ......and normally it drops on the floor but sometimes it also comes under inside of the car and spill on the carpet at the passenger side. I have checked the Power steering fluid and brake fluid and their quantities are not going down at all. The fluid is light pinkish in colour and there is no smell to it.
Please advise me as what it could be? but i havent noticed any probs with the car in any aspect, so shall i leave it till something stops working or get it checked
i am really good at nothing
Kersh
PostPosted: Fri Mar 25, 2011 5:03 am Up
heater matrix?
Member number: 36
Danw_VVT
coolant?
EDIT: get it checked to
Seb
PostPosted: Fri Mar 25, 2011 5:05 am Up
Staff - Seb
Could well be coolant?
PostPosted: Fri Mar 25, 2011 5:10 am Up
I agree! with all the above
What colour is your anti-freeze?
vanman_foci
PostPosted: Fri Mar 25, 2011 5:11 am Up
Yeah sounds like the heater matrix got a leak
shop.ebay.co.uk/?_from...Categories
robdob
PostPosted: Fri Mar 25, 2011 5:14 am Up
Deffo heater matrix, I had this and changed it now no problem Smile can get a brand new one off ebay for like 40 quid Smile
montysingh
PostPosted: Fri Mar 25, 2011 5:16 am Up
Hi Guys
Thanks for such a quick response, but if its coolant, the car is not overheating at all and the coolant level is still the same from ages, and if it is heater matrix, would i notice any difference in driving or any noise of any kind ?
montysingh
PostPosted: Fri Mar 25, 2011 5:34 am Up
Hi guys
also, if the heater matrix is leaking, will the car be making like watery sound like water is gushing through something
Kersh
PostPosted: Fri Mar 25, 2011 5:37 am Up
yeah there was a thread on this recently about a flowing water sound
its pretty much guaranteed to be heater matrix..
Member number: 36
montysingh
PostPosted: Fri Mar 25, 2011 5:41 am Up
Hi Kersh
But i am not having the watery issue at all with my Car
There is no sound of water gushing ? or running water or any water at all
can it still be heater matrix
Rob2859
PostPosted: Fri Mar 25, 2011 5:42 am Up
keep your eye on the water level. If when you are driving is continues to go up even after the fan haskicked in stop straight away even before it gets to the red.
PostPosted: Fri Mar 25, 2011 5:47 am Up
Is your coolant pink? If you have blue anti-freeze then you can say it's not the heater matrix. If it's just a few drops you wouldn't notice the coolant going down until you had lost a more than a few ml. You could always get your cooling system pressure checked at a local garage just to make sure.
montysingh
PostPosted: Fri Mar 25, 2011 5:49 am Up
Hi Rob
The car never overheats at all, the temp gauge always stay below 90
montysingh
PostPosted: Fri Mar 25, 2011 5:51 am Up
Hi Macca1411, The coolant is actually pink and pretty much same color of the fluid coming in car, so its heater matrix then i believe
