Online Now [267]:
Visitors: 266
Today: 168257
Total: 155461127
Forums › The Car › 206 Talk › need help!!!
need help!!!
Forum Index › 206 Talk
Ruraidh206Brown
PostPosted: Fri Mar 25, 2011 4:58 pm Up
when i indicate to got right my indicator works fine but after my steering wheel locks to its normal position the indicator is still indication to go right??? do i need a new bulb???? HELP
Peugeot 206 1.1L
PostPosted: Fri Mar 25, 2011 5:02 pm Up
If I understand your post, it sounds like a problem with the self cancelling mechanism in the steering wheel.
Matt
PostPosted: Fri Mar 25, 2011 5:08 pm Up
Trade Rating: +32
New stalk I think.
About £20.
Message Lee I'm sure he is selling a few.
Ruraidh206Brown
is it easy to sort?
Peugeot 206 1.1L
robertmarcs
PostPosted: Fri Mar 25, 2011 5:56 pm Up
either a problem with the comms/ stalk unit or the rotating switch behind the steering wheel.
PostPosted: Sat Mar 26, 2011 3:21 am Up
You'll have to take the steering wheel off to get to the self cancelling mechanism & the steering column cowling to change the indicator stalk. Shouldn't be that hard.
Pugsy
PostPosted: Sat Mar 26, 2011 5:11 am Up
i've got that problem but mine decides to indicate left after its cancelled goin right just have to flick it back to where it should be and its fine Smile
Pugsy206asw
jimjam19927
PostPosted: Sat Mar 26, 2011 6:42 am Up
Lee has a guide on his fs bit takes 2 mins
Member: 685
I Over Use Smilies Razz
