Posted: Sat Mar 26, 2011 8:44 am |
That wiring is normal.
This is what my plug looked like...the wiring is twisted through the shielded sleeving.
Posted: Sat Mar 26, 2011 1:00 pm |
| Lee wrote: |
What years the car?
Might be just the throttle thats messed up |
1999
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Sat Mar 26, 2011 1:01 pm |
| Edward wrote: |
dam thats clean, what is the that ontop of the thermostat housing? thats not standard isit? if it is i don't have 1 lol
| *DEAD*206 Gti 138
Posted: Sat Mar 26, 2011 2:06 pm |
It's a horrible coolant temp sensor for the Omex ECU. It sits in the hole that the bleed screw will be on yours. It's getting changed in a couple of weeks when my Samco hoses arrive (at last).
Posted: Sat Mar 26, 2011 2:26 pm |
| leigh_boy wrote: |
sesnor that have been replaced with NEW
coolent, crank sensor, cam sensor, TPS, Idle control valve, Air Temp sensor, 1 injector, o2 Sesnor and the map sensor
center exhaust pipe, rear box, spark plugs
also checked the timing yestaday
running out of things to change |
The car
You have wasted enough money on this one so far throwing new parts at it in an attempt to fix it
Posted: Sat Mar 26, 2011 2:28 pm |
| MrBSI wrote: |
| leigh_boy wrote: |
The car
You have wasted enough money on this one so far throwing new parts at it in an attempt to fix it  |
it only cost me £280 to begin with so think its still wortha bit more hassle not much tho
| *DEAD*206 Gti 138
Posted: Sat Mar 26, 2011 2:36 pm |
| leigh_boy wrote: |
| MrBSI wrote: |
| leigh_boy wrote: |
The car
it only cost me £280 to begin with so think its still wortha bit more hassle not much tho |
It sounds like your just slowly rebuilding the car from new parts & crossing your fingers one of these parts is gonna fix it.
Posted: Sat Mar 26, 2011 2:38 pm |
| MrBSI wrote: |
| leigh_boy wrote: |
| MrBSI wrote: |
| leigh_boy wrote: |
The car
It sounds like your just slowly rebuilding the car from new parts & crossing your fingers one of these parts is gonna fix it. |
your about right on that 1, soon i will get an engine, and a ecu / wireing
| *DEAD*206 Gti 138
Posted: Sat Mar 26, 2011 2:44 pm |
back to what lee was saying whats CAN ?
| *DEAD*206 Gti 138
Posted: Sat Mar 26, 2011 2:46 pm |
| leigh_boy wrote: |
| back to what lee was saying whats CAN ? |
Controller Area Network
Posted: Sat Mar 26, 2011 2:52 pm |
and the relivance to the question??
| *DEAD*206 Gti 138
Posted: Sat Mar 26, 2011 2:54 pm |
| leigh_boy wrote: |
| and the relivance to the question?? |
Multiplexed 206's use it.
The wires twisted like that look like typical CAN twisted pair wiring.
Posted: Sat Mar 26, 2011 3:32 pm |
| leigh_boy wrote: |
| Lee wrote: |
What years the car?
1999 |
so what could be messed up about the throttle?
| *DEAD*206 Gti 138
Posted: Sat Mar 26, 2011 4:05 pm |
Take it to a garage with either Pug Planet, Multi Di@g or Bosch KTS or something similar.
Not the w**ky generic EOBD readers
Posted: Sat Mar 26, 2011 4:14 pm |
im going to book it in for ecu firmware updates next week its only £40 so will ask about diagnotics but don't want to spend loads at a dealer as i feel violated going to a dealer lol
| *DEAD*206 Gti 138
