Forums › The Car › 206 Problems › ABS kicking in |
Posted: Sun Mar 27, 2011 3:23 am |
IF its any help,
I had many problems with the ABS on the 180, I had a few ABS rings and sensors replaced, but the problem turned out to be some wiring under the car that had broke and that was causing the ABS to flick on and off....mostly off.
Posted: Mon Mar 28, 2011 7:20 am |
Trade Rating: +59
Big_Rich180 wrote: |
IF its any help,
I had many problems with the ABS on the 180, I had a few ABS rings and sensors replaced, but the problem turned out to be some wiring under the car that had broke and that was causing the ABS to flick on and off....mostly off. |
Cheers Rich, but had a look and the ring is cracked on the passenger driveshaft.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sat Apr 02, 2011 12:33 pm |
Trade Rating: +59
Crawled under the car during the week and seen the passenger side ring had cracked. Replaced this today, after a bit of a fight trying to drift it onto the driveshaft...
All sorted now, will do the other side next weekend for peace of mind.
