Online Now [1221]:
Visitors: 1220
Today: 175508
Total: 155265876
Forums › The Car › 206 Problems › leaking but where and what is it?
PostPosted: Sun Mar 27, 2011 10:24 am Up
Noticed this morning when I moved the pug small wet patches on the driveway on drivers side (brand new, woops) had a look under the car and noticed a flat horizontal plate near the steering arm etc was wet with some sort of greasy fluid (not coolant or engine oil) brakes feel fine as does power steering and engine temps are fine, anybody know what it could be and where it could be coming from without me taking it to a garage??
PostPosted: Sun Mar 27, 2011 10:28 am Up
color? did you smell it?
transmittion oil smell a bit sulphur
PostPosted: Sun Mar 27, 2011 10:33 am Up
there's no smell to it at all, its like a light brown colour
Does it feel oily?
mattievrs
PostPosted: Sun Mar 27, 2011 10:35 am Up
Condensation from the Air con condensor?
NO LONGER ACTIVE ON THE FORUM
PostPosted: Sun Mar 27, 2011 10:39 am Up
Yeah it does Edward, gotta pick the mrs up in a min so will check to see if it's a constant leak or if it just leaks after a drive
benashley
PostPosted: Sun Mar 27, 2011 10:44 am Up
You sure its not coolent? Could be coming from the water pump
PostPosted: Sun Mar 27, 2011 11:15 am Up
Run your hand along the bottom of the coolant reservoir. The joint between it and the hose at the back of the engine can leak.
PostPosted: Sun Mar 27, 2011 11:34 am Up
Just had another look with my dad and it does seem to be just coolant, think mainly it's due to it being overfilled when the cambelt was changed, ran my hand underneath the coolant tank and its quite dry so it appears to be coming from the cap when the engine is hot
PostPosted: Sun Mar 27, 2011 11:58 am Up
Does it taste horrible?
PostPosted: Sun Mar 27, 2011 12:18 pm Up
lol
you taste any unknown fluid on the foor? Shocked
PostPosted: Sun Mar 27, 2011 12:20 pm Up
[quote="Edward"]Does it taste horrible?[/quo
haven't tasted it but if it leaks again will do, already know coolant tastes like so should tell straight away
PostPosted: Wed Mar 30, 2011 10:13 am Up
checked it again and it's still leaking and it's def the coolant as i tasted it Sad it's not from the water cap so thinking it's from underneath somewhere but there's only 2 pipes coming from it
millgate
PostPosted: Fri May 11, 2012 9:49 am Up
Any solution to this as I have just developed a similar problem car leaving wet patch....don't use air con, can see drops from plastic that travels round top of sump but am unable to see any trace apart from that FFS if it's not one thing it's another
cheers
Many thanks
millgate
PostPosted: Mon May 14, 2012 6:23 am Up
Looks like my leak is coming from water pump area but only just been fitted 2months ago WTF !!!!!!!
Many thanks
