Posted: Fri Oct 22, 2010 7:19 am |
no it has leda suspension 350lbs front an peugeot sport 23mm tb. the brakes are 330mm.
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
[img] [/img]
Posted: Fri Oct 22, 2010 7:43 am |
| rttam wrote: |
thats what the 180/rc engine looks like without the engine cover on
Looks like a 180/RC to me.
Posted: Fri Oct 22, 2010 7:47 am |
Trade Rating: -1
Coming along nicely! Wheels are cool. Looking forward to when i can afford insurance for a quicker car for the tracks!
Posted: Fri Oct 22, 2010 7:55 am |
with those extra pics thats actually quite well put together! lol.
Posted: Fri Oct 22, 2010 9:50 am |
Thank you pictures. Good luck on track.
| 2005 206 RC RED
Lot's of CNC machined customs pars.  | |
Posted: Thu Nov 25, 2010 5:53 pm |
a few pics from donington park
its now bin put away for the winter an some new parts soon hopfully.
Posted: Wed Mar 23, 2011 6:11 pm |
the interior is wrong becaus it was nicked when i was at the factory donig nothing. so the wrong trim is just from the scrappy lol.
Any way i'v bin bussy over the winter fitting throttle bodies. all the orginl wireing has ben removed and wired from scratch to a DTA s60 ecu. stll needs a few bits finshing off.
[img] [/img]
[img] [/img]
[/img]
[img] [/img]
[img] [/img]
[img] [/img]
Posted: Wed Mar 23, 2011 7:51 pm |
Want I had to abandon my ideas of TB'ing due to the wiring issues! How long/expensive was it?
Posted: Thu Mar 24, 2011 5:02 am |
Hi Simon.
Very good project. Please update constantly.
How did you convert your wheel nuts to bolts. I wanna do that but as you know standart peugeot nuts for rc wheels is slightly different. They have a washer on nuts. I think without this washer maybe wheel get in damage around nut holes.
| 2005 206 RC RED
Posted: Mon Mar 28, 2011 11:12 am |
The studs are from pug sport and the nuts have a flat face with a built in washer. I dont know realy i haw done all the wiring myself but it stll need a few little bits befor its finshed (rad, oil cooler, fuel/brake lines, airbox) so i havent worked it out.
Posted: Tue May 03, 2011 1:06 pm |
Where did you get the top mounts from?
PM me please
| Team Impossible Possible
Posted: Tue May 03, 2011 1:51 pm |
I missed this topic. Don't know why people would think it's not a 180 because you can see the VVT solenoid and the oil drain from the end of the head too.
The brakes look lovely. The AP Racing websire says the brakes will fit behind standard 16" wheels but they looks quite tight behind the 17" wheels.
What length trupets are you fitting to the bodies? I've got 50mm trumpets at the moment but I want to go for some 90mm trumpets with a custom shorter radiator.
Posted: Tue May 03, 2011 2:13 pm |
| Addaz wrote: |
PM me please |
ast top mount from ast.....
Posted: Tue May 03, 2011 2:20 pm |
i had the brakes custom made they are 330mm discs i dont think they would fit under 16's. the trumpets are 30mm i think i'm goning to try them an see how they work first. i will get a pictuer of them with my custom rad.
Posted: Tue May 03, 2011 3:00 pm |
Enjoying this so far, engine looks the same as mine.....
