Latest: dreyfalon
Overall: 17121
Online Now [281]:
Visitors: 280
Today: 89101
Total: 97389098
Forums › The Car › 206 Problems › deisel leak
deisel leak
goughy
PostPosted: Mon Mar 28, 2011 1:49 pm Up
as above it seems to be comming from the filler pipe, had a quick look tonight the top of the filler pipe is dry but deisel is dripping from the bottom bend from the tank, its not leaking from the tank though its further up the pipe as it goes up under the plastic cover in the rear wheel arch, is there a breather tube up there or anything that could cause a leak? any help would be appreciated colin
206 2l hdi sport
PostPosted: Mon Mar 28, 2011 1:53 pm Up
Probably the worst attempt of spelling Diesel I've ever seen Laughing
Just take the rear wheel off and have a proper look to see where it's coming from.
PostPosted: Mon Mar 28, 2011 1:54 pm Up
most diesel cars got a hose attached to the filler pipe,so when the diesel is full,and go out the filler spot,it don't spell on the car body,but it goes down to the ground,but not sure if that is the case in your car.
PostPosted: Mon Mar 28, 2011 1:58 pm Up
206 doesn't have one of them, it just p**ses out all over the car
Mr_Cellexe
PostPosted: Mon Mar 28, 2011 2:04 pm Up
indeed! lol
could be a bad seal/rip in the rubber join at the base of the filler leg.
goughy
PostPosted: Mon Mar 28, 2011 2:07 pm Up
lmao well done you've spotted the deliberate spelling mistake give yourself a gold star Laughing
206 2l hdi sport
goughy
PostPosted: Mon Mar 28, 2011 2:09 pm Up
Mr_Cellexe wrote:
indeed! lol
would this joint be behind the arch cover?
206 2l hdi sport
Mr_Cellexe
PostPosted: Mon Mar 28, 2011 2:38 pm Up
nope, the rubber/silicon join at the top of the tank and base of the filler leg/arm whatever! lol.
