Online Now [1355]:
Visitors: 1355
Today: 419840
Total: 153815721
Forums › The Car › 206 Talk › headlight adjustment help...
Forum Index › 206 Talk
robdob
PostPosted: Mon Mar 28, 2011 2:25 pm Up
so the masked valeos are on Very Happy and they are great except they are pointing at the floor and i have no idea how to adjust... any help would be great Smile
PostPosted: Mon Mar 28, 2011 2:28 pm Up
adjust the electronic adjuster from the top using an allen key or similar.
robdob
PostPosted: Mon Mar 28, 2011 2:30 pm Up
i tried that but i couldnt really notice a change or am i being a c**t? haha
drunknmunky
PostPosted: Mon Mar 28, 2011 2:39 pm Up
mine seem to be the same i moved the white screw bit round but it appeared to make no difference to where the light beam aimed Confused
and i kinda need to get mine sorted as i now have HID's and think i may be blinding people as there not lined up proper Sad
robdob
PostPosted: Mon Mar 28, 2011 2:48 pm Up
glad im not the only one... but it is a pain in the a**e...
PostPosted: Mon Mar 28, 2011 2:49 pm Up
Get a MOT garage to do it
robdob
PostPosted: Mon Mar 28, 2011 2:52 pm Up
i tried takin it to my local halfords garage mate and they said they wanted the car for a day because they couldn't fit me in... sounded well dodgy :/
Rob2859
PostPosted: Mon Mar 28, 2011 4:45 pm Up
I thought thats what they do anyway Very Happy
maybe the ajuster is broken like mine.
Still_Rolling
PostPosted: Mon Mar 28, 2011 4:49 pm Up
Adjusters are easily broken... did you have to take the old adjuster off the old headlamps?
Some for sale on here: www.206info.co.uk/Foru...27397.html
Always Rolling...
drunknmunky
PostPosted: Mon Mar 28, 2011 4:52 pm Up
i may have been moving another bit then as i didnt move anything on the black adjuster bit i just moved a hiwte screw near the indicator lens Confused im confused
is this some sort of other adjuster or what?
do i need to adjust it from the black adjuster box that goes on?
thanks
Still_Rolling
PostPosted: Mon Mar 28, 2011 4:54 pm Up
Yea, should be near the top corner of the lamp... my adjuster was a black one with a 3 pin plug on the bottom of it... white allen key fitting in that is the bit that needs adjusting.
Always Rolling...
drunknmunky
PostPosted: Mon Mar 28, 2011 4:57 pm Up
ooooo i think i may have been moving the wrong bit then whoops
anyone know roughly where you should put them like (eg park 5 metres from garage and put them at a certain height kind of thing)
Still_Rolling
PostPosted: Mon Mar 28, 2011 5:00 pm Up
Sorry, can't help there mate...
Good luck though!
Always Rolling...
drunknmunky
PostPosted: Mon Mar 28, 2011 5:01 pm Up
Good luck though!
thats cool you have helped loads already Very Happy
thanks
carlosr23
PostPosted: Thu Apr 07, 2011 9:12 pm Up
Mine has a wheel switch that has 4 settings, each aims the headlights at diferent levels. Just in case you have not checked.
Carlos\r\nPeugeot 206 s16 2004
