Online Now [1332]:
Visitors: 1331
Today: 13375
Total: 155315116
Forums › The Car › 206 Talk › Hub
Hub
Forum Index › 206 Talk
thompson69
PostPosted: Tue Mar 29, 2011 1:27 pm Up
Hi I only have 3 nuts in my drivers side front wheel so when I got new tyres on they said that 1 of the holes the nuts wont tighten up. So can anyone tel me if I have to change the full hub?
1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker
PostPosted: Tue Mar 29, 2011 1:30 pm Up
yes as i don't think you can change balf of the hub lol
i wouldn't trust re-threading the hubs hole though.....
thompson69
PostPosted: Tue Mar 29, 2011 1:39 pm Up
Thanks. Is it hard to do 1 with abs? I have never did 1 before
benashley
There bolts not nuts Rolling Eyes . Did you have 4 in each wheel before having your tyres changed? If you did the they probably cross threaded one when they fitted your tyres, So they should fix it.
You will need to change the hub and wheel bearing or get a complete second hand hub assembly and swap it over yourself. I would try running a thread cleaner/tap through it first and get get a new bolt and try that.
PostPosted: Tue Mar 29, 2011 1:42 pm Up
easy, not sure about the abs though because mine don't have abs.
not uncommon seeing damaged hubs due to those stupid people using air tools to over tighten the bolts.
thompson69
PostPosted: Tue Mar 29, 2011 1:52 pm Up
You know what I mean lmao. There was only 3 in when I got the car
thompson69
PostPosted: Tue Mar 29, 2011 1:58 pm Up
I hate it. This is my 2nd car that this happend
