Latest: SA01
Overall: 17138
Online Now [158]:
Visitors: 157
Today: 22859
Total: 112319706
Forums › The Car › 206 Problems › LCD Clock Ilumination Gone Out
planeturon
PostPosted: Wed Mar 30, 2011 8:56 am Up
The left side where the date is illuminated, but the right side is dark, I can still see what time it is, but it's very hard to see Sad
Any ideas what might be the problem? Thanks
206 2.0 hdi 2005
PostPosted: Wed Mar 30, 2011 8:57 am Up
Bulb
planeturon
PostPosted: Wed Mar 30, 2011 8:58 am Up
Just a bulb Laughing Cheers bud Wink
206 2.0 hdi 2005
PostPosted: Wed Mar 30, 2011 9:01 am Up
Screw driver under the rear of the shroud, pop it off, change the bulb.
Can't remember what bulb it is, buy I made a FAQ on it if you look in that section
Rob2859
PostPosted: Wed Mar 30, 2011 9:04 am Up
I replaced mine with LED ones. A fair bit brighter.
PostPosted: Wed Mar 30, 2011 9:05 am Up
You risk getting brightness spots tho
Rob2859
PostPosted: Wed Mar 30, 2011 9:32 am Up
The ones I got were cheap and the holders were of a very poor quality, they didn't fit properly. However the diodes were good and I didn't have any spots. A bit of A4 paper can sort spots out though.
mdstone
PostPosted: Thu Mar 31, 2011 1:27 pm Up
I had this problem with my old 206 and it wasn't the bulb, the wole unit had to be replaced but it was practically the whole of it that didn't light up unless you pressed against it. I didn't bother though, I sold it and bought my GTi.
Hopefully in your case the bulb will do the trick.
Peugeot 206 GTi
