Latest: DanDan17
Overall: 17128
Online Now [158]:
Visitors: 157
Today: 2414
Total: 100477252
Forums › The Car › 206 Problems › Engine continues to run....
nicholad
PostPosted: Thu Mar 31, 2011 5:25 am Up
I have noticed that when I park up and turn the engine off and remove the key the engine is still running. It doesn't happen everytime but when it does happen it the engine continues to run for a few seconds and then switches off. What is this - is it going to lead to a bigger problem. Many thanks for your advice N
Nicholad
kieron
PostPosted: Thu Mar 31, 2011 5:36 am Up
is it the dw8 1.9 engine?
Account suspended
Rob2859
PostPosted: Thu Mar 31, 2011 5:45 am Up
fuel cut off solenoid. Don't know where it is located
cartoonhead
PostPosted: Thu Mar 31, 2011 6:00 am Up
I agree!
normaly on the pump.
Rob2859
PostPosted: Thu Mar 31, 2011 6:18 am Up
Its strange I had that problem a few times but then it was fine after. I think it got water logged.
PostPosted: Thu Mar 31, 2011 6:20 am Up
Wrong bulb in the rear cluster for stop / tail can cause ignition faults Wink
1.4 GLX in profile, its gonna be a TU3 lump.
Debbie22
PostPosted: Thu Mar 31, 2011 8:07 am Up
that happened to my 306 and turned out it was head gasket :/
PostPosted: Thu Mar 31, 2011 8:32 am Up
What He Said
Send +12v down the side light wire and the ignition comes on Wink
PostPosted: Thu Mar 31, 2011 8:36 am Up
Originally found out by Ricky / Porndog all those years ago Laughing
nicholad
PostPosted: Thu Mar 31, 2011 9:14 am Up
Thanks for your replies - my car is indeed a 1.4 GLX. You mentioned a light bulb? I did have a rear light out a couple of weeks ago and the bulb was replaced - could the engine running fault be down to that then? Also I have noticed when I drive in the dark my tail light is permenantly on too.....
Nicholad
PostPosted: Thu Mar 31, 2011 9:19 am Up
Bingo Wink
Make sure the stop / tail bulb is the correct twin filiment 5w21 type & its fitted the correct way round.
Didz
PostPosted: Thu Mar 31, 2011 9:54 am Up
gotta love an easy fix Smile
on the leci tricks, if you turn the hazard switch round in a nova 14sri you can bump the car and it runs Surprised
Life's for living....
PostPosted: Thu Mar 31, 2011 9:59 am Up
Thats old school Vauxhall.
There is a similar one for the first generation Vectra but I aint posting it up on a public forum Laughing
Reminds me of the first generation Peugeot / Citroen alarm & immobiliser system, that was so easy to bypass in seconds Laughing
mdstone
PostPosted: Thu Mar 31, 2011 1:21 pm Up
Does this mean we can all go and hotwire a 206?
pug206lx
PostPosted: Thu Mar 31, 2011 1:25 pm Up
Nope. Immobiliser cuts in.
