Posted: Thu Mar 31, 2011 10:10 am |
Posted: Thu Mar 31, 2011 10:14 am |
I'm unsure.
just posting to say I saw you run the 1/4 mile
Posted: Thu Mar 31, 2011 10:17 am |
The pain staking slowness! at least i put my mate and his fezza in place
I watched you towards the end of the day, did you see the lad in the black MG? ouch!
Posted: Thu Mar 31, 2011 10:19 am |
due to the fact that indicators work on resistance you will need a resistor with those LED indicator bulbs or they will flash too fast (as if you have a bulb out)
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Thu Mar 31, 2011 10:23 am |
MrrNoName wrote: |
due to the fact that indicators work on resistance you will need a resistor with those LED indicator bulbs or they will flash too fast (as if you have a bulb out) |
Is it just the indicator that would require a resistor then? If so I will skimp on the indicator lol
Posted: Thu Mar 31, 2011 10:25 am |
Andrewxps wrote: |
I watched you towards the end of the day, did you see the lad in the black MG? ouch! |
Yeah 20 seconds...
Good on you for having a go though.
Yep, nasty crunch! Driveshaft or gearbox.
There was an oil spill right at the end of the track on one of my runs, went over it at 90mph... scary!
Posted: Thu Mar 31, 2011 10:31 am |
CD-vRS wrote: |
Andrewxps wrote: |
Yeah 20 seconds...
There was an oil spill right at the end of the track on one of my runs, went over it at 90mph... scary! |
19! In twelve months when I can afford to insure it I would like a cat back exhaust, cold intake and a remap and see if with better take off as well i can shave a couple seconds off
Enjoying the VRS then?
Posted: Thu Mar 31, 2011 11:15 am |
I have heard that you should use the Red LED's with Red lenses, Im not sure why tho
Posted: Thu Mar 31, 2011 11:25 am |
On which light mikey, reverse and indictor?
Posted: Thu Mar 31, 2011 11:40 am |
Red LED's mate in tail lights with red lenses
Posted: Thu Mar 31, 2011 11:53 am |
Has LED's in phase twos been done before? Ive just been told it wont make any noticeable difference
Posted: Thu Mar 31, 2011 12:39 pm |
Trade Rating: +32
Won't it just make the red bits shine pink lmao.
Posted: Thu Mar 31, 2011 1:01 pm |
If you put the white LED's in behind the red lense they do look a bit pink. I think someone has done it with the third brake light. I'm not sure if standard LED will be bright enough, you could try SMD LED. They are a lot brighter. I'm saving the pennies to buy the P21/5 ones for my rears
Posted: Thu Mar 31, 2011 1:02 pm |
I think I'm going to stay standard, too much money and effort with resistors on something that I won't really be looking at for something I am told wont make a difference
Posted: Thu Mar 31, 2011 1:05 pm |
I've got some white led already, I will try them in the indicators over weekend and see if it makes a difference
