Latest: Andyblue64
Overall: 17123
Online Now [187]:
Visitors: 186
Today: 34087
Total: 98063469
Forums › The Car › 206 Talk › fog/sidelights
fog/sidelights
tiago90
PostPosted: Mon Apr 04, 2011 8:31 am Up
if i wire my fog lights to the sidelights, will it be too much power for the cables ?
PostPosted: Mon Apr 04, 2011 8:33 am Up
Yes. Plus it's illegal to drive with them on if not in foggy conditions.
tiago90
PostPosted: Mon Apr 04, 2011 8:34 am Up
Thank you Smile
Big_Rich180
PostPosted: Mon Apr 04, 2011 8:35 am Up
And you will look at tool having your sidlights and fogs on all the time.
Aar_Im_A_Pirate
PostPosted: Mon Apr 04, 2011 9:57 am Up
Also, why would you wire them up to your side lights? It's not much hassle to twist the switch for the sidelights then twist the wee switch for the fogs.
Team: Derv
PostPosted: Mon Apr 04, 2011 10:10 am Up
What He Said
Dabamash
PostPosted: Mon Apr 04, 2011 10:18 am Up
Staff - Daba
I believe it is a £30 fixed penalty at the moment for driving with your fog lights on in conditions that do not warrant it
Coolspot
PostPosted: Mon Apr 04, 2011 11:02 am Up
Get some daylight running lights if it the look you are going for.
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Mon Apr 04, 2011 11:06 am Up
i though is 3 pts+ fixed penalty?
PostPosted: Mon Apr 04, 2011 11:07 am Up
Nah just a fixed penalty, same as not wearing a seat belt or dodgy number plate
vintageoriginal
PostPosted: Mon Apr 04, 2011 11:35 am Up
What about putting sidelights in your foglights? I know someone on here has done this.
Quiksilver: 1.6 16v Engine Conversion.
Coolspot
PostPosted: Mon Apr 04, 2011 11:50 am Up
All depends on the markings on the lights, I believe 206 fog lights are marked for fog use using some code.
PostPosted: Mon Apr 04, 2011 11:56 am Up
You could put SMD H1s in your fog lights and wire them to the side lights. People are correst in saying it is a fied penalty for driving with them on, but that is if they are auxillary lights, if they come on with the same switch as the side lights, they are no longer classed as auxilary lights. As SMD aren't as bright you could use them as running lights and not need to alter the wiring as they only draw a small current. There is no MOT requirement for front fog lights as they are not covered by the vehicle lighting regulations, so in theory they don't need to work. I do agree that cars driving roind with their fogs on look pretty daft. I would go for som e of the Prism LED running lights and put them inside the headlamp units if that's the look you're after. You could drill a hole on the fog light and fit a push type 501 connector. IMO this would give a much nicer effect.
ma.langan
PostPosted: Mon Apr 04, 2011 12:01 pm Up
i put H1 SMD in my fogs and wired them to my sideys and not been pulled yet, they not that bright but look nicee
Farmer T'aaron!
vintageoriginal
PostPosted: Mon Apr 04, 2011 12:13 pm Up
Any chance of a piccy langan?
